Old 08-26-2016, 10:40 AM   #1
buddyu's Avatar
Leveler dropping
Has anyone had a problem with a leveler dropping after they have been retracted? This is happening with the right front one. It drops to where it is about 4-5 inches off the ground. There are no leaks.
buddyu is offline   Reply With Quote
Old 08-26-2016, 12:00 PM   #2
I have the same problem except mine was the left front and the one leveler might go all the way to the ground. I posted the almost same question here a month ago and one answer I got was the fluid might be low. They had the same problem and after adding fluid the leveler didn't drop any more. My fluid reservoir is a little low, but I haven't had time to add any yet. If you check your reservoir check it with the jacks, {levelers} up and all slides in. Mine would only drop maybe 1 1/2 to 2 inches over two weeks, but one time it was either touching ground or almost there. On mine that is the closest leveler to the pump.
Let me know what you find. It will be at least 2 to 3 weeks before I have time to go to the storage lot to check mine.
Good luck!
Wattsworld is offline   Reply With Quote
