Old 05-25-2015, 05:21 PM   #1
Levelers and slide problem
I just purchased a 2004 Georgetown 359 class a. Having an issue. When I level coach once level the front slide comes out with level controls not slide control. If I try slide control nothing happens. However the two bedroom slides work normal. Anyone have any ideas? It has a lippert level slide system.
Trucky315 is offline   Reply With Quote
Old 05-28-2015, 10:49 AM   #2
Iggy's Avatar
My best bet is that one of your valves at the valve body(attached to reservoir) is leaking by the valve.
It also may be that the valves are not totally closed and the allen screws need to be opened and closed that are located at the end of each valve.
It just may be contaminated oil as they say you should replace the Automatic Transmission Fluid (ATF) every few years and flush the whole system.
You can do it yourself as it takes the regular cheap ATF fluid.
ID:	78328   Click image for larger version
ID:	78329   Click image for larger version
Old 05-28-2015, 10:53 AM   #3
Iggy's Avatar
Here are a few manual's if you don't have them.
Yours may not be the same as it is older than mine.
File Type: pdf 002_electronic-leveling-plus_manual.pdf (1.70 MB, 55 views)
Old 05-30-2015, 12:16 PM   #4
Iggy, how the heck do you keep your valves and lines so clean? Mine have oil residue all over them.
sherman12
2011 Georgetown 330TS
Kia Sportage on MasterTow Dolly
sherman12 is offline   Reply With Quote
Old 05-30-2015, 02:17 PM   #5
Iggy's Avatar
This was a very early picture when new. But to answer your question I wash them with a hose every now and then. I do wipe the valve bodies down and try to keep it as clean as possible.
This way I'm able to see if I have any leaks.
I now have 36,000 miles and have noticed the orange color lines are starting to fade.
Thanks it.
Old 05-31-2015, 11:35 AM   #6
Thanks Iggy!
sherman12
Old 06-01-2015, 09:57 AM   #7
Thanks for all the help. I agree I think i have a valve sticking. I was able to find some old manuals online.
slide
