Old 11-09-2013, 08:13 PM   #1
43D18's Avatar
Levelers going nuts on GT 351
The levelers on our Georgetown 351 have never been right. On the way home from the dealer we leveled the coach in a Wal-Mart parking lot and they lifted the front end off the ground completely even though it wasn't that far out of level to begin with. After the "leveling" process was complete, our entry door would not close. In the weeks since then we've just used the manual leveling setting and not the "auto" setting. While in the shop to address a slide issue, we had the tech look into the leveler situation - it did the same thing for him setting on nearly level ground. So he "zero'd" out the system. He cycled it several times and it returned to level each time. We are staying in the coach while waiting for a part to come in for the slide, so we are camping not far from the dealer and we tried the auto setting at this campground on a spot that needed a bit of leveling- the system kinda went nuts, finally ending in an "error" code with both the right and left led's flashing. So....looks the levelers will need attention too.
Yet another situation to put the FR warranty system to the test, and we will indeed report back.
-Mike
Mike & Suz
2014 Georgetown 351
Pontiac Vibe toad
Buck & Patsy, the boston-mix guard dogs
43D18 is offline   Reply With Quote
Old 11-10-2013, 09:38 AM   #2
I found it so much easier to install a pair of cheap bubbles next to your control and use manual. Start by running both back jacks till they touch ground, then do the same for front and then go from there.
johnnypal is offline   Reply With Quote
Old 11-10-2013, 09:49 AM   #3
43D18's Avatar
That's exactly what I've been doing. Still beats using wood blocks. But I would like for the auto setting to work.
Mike & Suz
2014 Georgetown 351
Pontiac Vibe toad
Old 11-10-2013, 05:16 PM   #4
armye7's Avatar
You have to zero out the system first if u want to auto level your coach!
armye7 is offline   Reply With Quote
Old 11-10-2013, 05:25 PM   #5
Fulltime family RVer
Sounds like the dealer's tech did that.
ependydad is online now   Reply With Quote
Old 11-10-2013, 05:32 PM   #6
armye7's Avatar
I would be surprised, I'm on my second Georgetown both had to be zeroed to keep tires from coming off the ground.
Old 11-10-2013, 05:39 PM   #7
43D18's Avatar
As stated in my original post, the system has been zeroed out, but is still operating erraticly.
Mike & Suz
2014 Georgetown 351
Pontiac Vibe toad
Old 11-10-2013, 05:44 PM   #8
armye7's Avatar
Sorry did not see that post. That is usually the problem.
Old 11-10-2013, 05:46 PM   #9
Ford Idaho's Avatar
Just out of curiosity what does "zeroing" entail?
Old 11-10-2013, 05:48 PM   #10
armye7's Avatar
It's series of buttons u push on your level control pad. It's on a post on here, takes about 2 minutes to complete.
