On the pump assy find the solinoid that works that jack pull it out of the unit and on the very end there will be a small Oring, you most likely will not see anything wrong with it but it can still be bad. Should cost you about 5 cents at a hyd. shop. Do not use just any old oring. Simplest and cheapest thing to check first. Found this on my 06 after spending a ton and if it is not the fix your only out a nickle.
George & Jerri
06 GT 340 TSSE
USMC
