Old 09-12-2014, 12:21 AM   #1
hazbunch's Avatar
Leveling Jack Alarm
After a few minutes or up to a few hours, my alarm goes off for the leveling jacks being down. I have to hit the up button to clear it every time. I have looked at the jacks and they are always in the full up postion. Has anyone had this issue?
hazbunch is offline   Reply With Quote
Old 09-12-2014, 03:57 AM   #2
Witch Doctor's Avatar
That must be scary if your on the road?
Coachmen M/H
Concord
2018 / 300 DSC
Old 09-12-2014, 08:29 AM   #3
bubbles's Avatar
This is from the manual:
The TOUCH PAD will sound an alarm and the TOUCH PAD
will flash all lights for either of two possible reasons; (1) A
“RETRACT” hose is leaking or (2) the pressure holding the
retracted jacks falls below 1500 psi.
I would check that all actuator (at the main manifold under the step well) allen head screws on the end of the actuators are adjusted fully counterclockwise after verifying no leaks are detected.
Old 09-12-2014, 07:13 PM   #4
jergeod's Avatar
Give us and idea of year and model of coach please.
George & Jerri
06 GT 340 TSSE
USMC
jergeod is offline   Reply With Quote
Old 09-12-2014, 08:48 PM   #5
Iggy's Avatar
It will also go off if the fluid level is too low and it can't maintain pressure to hold jack up.
Old 09-12-2014, 10:21 PM   #6
hazbunch's Avatar
Thank you I will check the fluid level and make sure all the Allen heads are tight. I have a 2011 360.
leveling
« Steps | Shocks »
