Old 05-23-2019, 03:17 PM   #1
Leveling Jacks Control Panel
Not sure if I'm posting this in the correct place but I need to replace the circuit board for the control panel for my leveling jacks. Motor home is a 2002 Georgetown. Part number is DN 12558. Any help will be appreciated
Jasper J. 44 is offline   Reply With Quote
Old 05-24-2019, 10:06 AM   #2
It is an older system but Lippert still has information about them here.
https://support.lci1.com/dewald-leveling-system
I also have the manual attached
You may have to call Lippert and ask them.
Good luck
Old 05-25-2019, 07:08 AM   #3
Thanks Iggy. I found out that this board has been discontinued and no longer available. They seem to be pretty scarce. I found M & M RV Electronics will rebuild my board so I should not have to worry about replacing with a used part.
Thanks for your help
Old 06-26-2019, 06:40 AM   #4
Just thought I'd let you all know I got my control board back from M & M Electronics. It works like a new one. They did a great job, a little pricey but these things are almost impossible to find used. Can't say enough good about the customer service.
