Old 09-04-2012, 08:49 AM   #1
Leveling System
I have a 2004 Georgetown 36 ft. I have lost power to my leveling system control panel, I have to owners mannual. Where is the source for power to this unit, I can't find it under the dash, under the hood or under the steps. I had a 5 amp fuse blown under the steps, I have a 15 amp fuse with no power to it under the hood in the fuse panel and the 15 amp fuse that feeds the controller has no power to it. Also the radio has no power or the cigar lighter. I could use some help, any suggestions?
retiredbodyman is offline   Reply With Quote
Old 09-04-2012, 12:27 PM   #2
Have you checked these?
I bet it is the 100 amp resettable one mounted on the back wall will be the one that needs resetting.
Opps I just reread your message.
If the radio and dash is out you may have to check the fuse panel in the engine compartment behind the airfilter box.
Old 09-04-2012, 12:31 PM   #3
Additional Information
Here is a picture and list what is in the under the dash panel.
ID:	19108   Click image for larger version
Old 09-04-2012, 12:33 PM   #4
Is the Ford Battery charged and you have headlights etc?
Have you started the Motorhome and checked?
Old 09-05-2012, 08:02 PM   #5
Just went through it with mine. It was the breaker by the batteries
bigscontis is offline   Reply With Quote
Old 09-06-2012, 07:53 AM   #6
fuse block
I can't find the fuse block under the dash, I"ve checked the one under the hood and steps
Old 09-06-2012, 08:19 AM   #7
The one under the dash is on the drivers far side left.
It has a black cover on it that can be removed.
Old 09-08-2012, 07:29 AM   #8
ogarcnod's Avatar
Check the 100amp fuse in battery box same thing happened to our 2012 351ds reset fuse all was good
ogarcnod is offline   Reply With Quote
Old 09-10-2012, 11:08 AM   #9
what is the common practice for leveling, rooms in or out before leveling, I have 37'8" Georgetown
Railroadman is offline   Reply With Quote
Old 09-10-2012, 11:11 AM   #10
Book says to level before you put slides out.
If you need the book let me know.
Old 09-10-2012, 11:23 AM   #11
ogarcnod's Avatar
Always level before putting slideout out make sure that you are only one in coach that's best if not make sure any others stay still until coach is level and if on unlevel site crib up jack pad so you don't over stress jacks we do this and have no problems
