Old 09-26-2014, 10:53 PM   #1
borba's Avatar
leveling system
hi im having a problem with my leveling system the jacks don't retract any body have any ideas how to fix I try evrething but no lock nice weekeng for camping but stock on my yard cant move need help thaks
borba is offline   Reply With Quote
Old 09-26-2014, 11:41 PM   #2
Krazymace's Avatar
I would guess you have tripped the breaker to your hydraulic pump. On my coach the breaker is located in the vicinity of my batteries and the pump. As I recall, a red lever pops out. Push the lever in and that should solve your problem. Otherwise, call Lippert and they will walk you through it.
Krazymace is offline   Reply With Quote
Old 09-28-2014, 01:02 AM   #3
Cornelius's Avatar
Welcome to the Georgetown Forum!
In addition to the circuit breaker, there is usually a fuse located near the hydraulic pump in the wiring harness. There are also two fuses used by the slide-outs and jacks that are inside the black metal solenoid box near the house batteries.
2010 Georgetown 373
2013 Jeep Wrangler
Cornelius is offline   Reply With Quote
Old 09-28-2014, 08:29 AM   #4
borba's Avatar
thank you for the help I got then up with a drill but still nothing works will book for services its a 2014-335
Old 09-29-2014, 06:23 PM   #5
Double D ..question, does your slide out work?
I have a similar problem on my 2014 georgetown 377. Nothing works.
Local tech. Is sure the pump is not working, Lippert has new one on its way. All electrical is fine, unfortunately my one slide out is out so we can't move rig......
double D is offline   Reply With Quote
Old 09-29-2014, 07:52 PM   #6
borba's Avatar
Double D my slides working find but for you there a way to close by hand never dit it bur I read on the forestriver manul
2015-georgetown 378xl
2013-ford fx4
2009-harley flhx
Old 10-07-2014, 07:17 PM   #7
DAB2014's Avatar
Control Panel Reset
Had same problem. Jacks were overextended. Are lights flashing on control panel? Hold in all four buttons (left, right, front, back) for about five seconds to reset.
DAB2014 is offline   Reply With Quote
leveling
