Forest River Forums
Sunline User Photos
Old 11-26-2011, 09:30 PM   #1
Light above sofa
I have a Georgetown 378. We have a sofa and chair next to each other with 3 lights above them. One of the lights are out and I've taken the bad one out but I don't see any lettering on it to indicate what kind of lamp it is. It's distinguishing feature is two prongs that get seated into its holder. I bought a 2040 but that can't be it because its prongs are wrapped in glass.
georgetown50 is offline   Reply With Quote
Old 11-26-2011, 09:56 PM   #2
Moderator
Terier's Avatar
You might try removing one of the good bulbs and see if you can read the number. I went into the same problem when I needed to replace a bulb but couldn't tell what size. I called the service department after I couldn't find it in the paperwork. In my case it was a 921 bulb but I have a travel trailer.
16 Trips / 43 Nights / 1204 Miles
Old 11-27-2011, 01:37 AM   #3
Ok, I may try that. It isn't one the one that is bad.
Old 11-27-2011, 07:37 AM   #4
cfsoistman's Avatar
Take the bulb to Walmart and match it up. It's 12 volts and will be around the area where the automotive bulbs are. Chances are it is the 921 as Terier stated.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 11-28-2011, 06:32 PM   #5
I have the same light setup on my 347. 3 lights mounted unter the cabinet over the couch. I recently replaced them all with led bulbs. They last longer, give same lumen value and don't give off any heat to speak of.
I don't know the number of the original incandescents, but the leds are G4. They are a little pricey ( $12-13 a piece). I bought mine from prudetrver.com. At the time, they had the best price. However There may be some cheaper options out there
Hope this helps
bendrver is offline   Reply With Quote
Old 11-29-2011, 11:12 AM   #6
accumack's Avatar
check out lowes for led bulbs my berkshire uses several different bulbs over the couch and over the table. i converted from incadescent to led. i believe less than $9 for mine.
accumack is offline   Reply With Quote
» Online Users: 261
13 members and 248 guests
1l243, bama gail, bignugget, bikendan, elind, F.R.O.G., Greene, Namchief, onthelake, Rebel702, Rsgtivr6, sprayking, srj
Most users ever online was 996, 05-22-2012 at 11:04 AM.
Close [X]
