05-26-2014, 08:57 PM
Light under cabinet over sink
Has anyone had to replace the light bulb under the cabinet on a 378? I cannot get the darn fixture off. Frustrating!!
05-27-2014, 07:36 AM
What type of fixture is it? The round ones you have to push to turn on/off?
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
05-27-2014, 08:05 AM
It's the round one with chrome ring.
05-27-2014, 08:35 AM
CLASS "A" Senior Member
Sounds like the type we have over the sofa. It's similar to a bayonet bulb. I have to palm the lens. push in slightly and turn to the left [counterclockwise], ease up on the pushing and you should have the lens in your hand.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
05-27-2014, 08:41 AM
It is like the ones over the sofa. I will give it a try. Thanks!
05-27-2014, 07:27 PM
Kanadian Kamper
Sometimes to get a better grip on removing these lights, I use the thin rubber non-slip pad material they sell so items on your car dash won't slide, and palm the material between my palm and the light lens.
Might help IF the lens were to break too
Ken and Terry
05-29-2014, 05:14 PM
We're having the exact same issue also with the over-sink/under-cabinet light! Sadly, it is not like the "cans" in the ceiling which you can push in and rotate - these don't push in or rotate at all that we can tell (and Boy Howdy, we've tried!) . . . it almost seems like they should be pried or popped off to get to the bulb.
Here's a picture that might help someone with greater experience and wisdom than we (which should be most everyone here) assist us - 'cause having no light there sure makes cooking and cleaning up a PITA!
Any help is greatly appreciated - thanks!
Lisa and Frank
2008 Georgetown SE 350 - "The Flying Wasp"
No Tow Car
Two Cats
05-29-2014, 05:59 PM
The lens rotates counter clockwise to remove it from fixture. I know it doesn't seem like it but it does. I pried one out of the ceiling before I figured it out. On the positive side once you get out once they work easier. Someone mentioned to use a sticky surface to help remove. Something like a silicone pad used to remove lids would probably work well. Good Luck!
Rudy - 10 year old long haired dachshund, RIP
2011 Georgetown 350TS
2013 Chevrolet Equinox toad
05-29-2014, 06:26 PM
Thanks, Rudy for the quick response and the help - I do very much appreciate it!
I was able to try this with one of the lights above the sofa (easier to access) and indeed, after some effort, was able to push the lens in and rotate it . . . funny story though, because it had been siliconed in the metal ring it wouldn't pop out of it and just would rotate and rotate and rotate - so I eventually pried it out of the ring and broke it in half.
So, now I'm rather reticent to try this with the light over the sink and break that lens as well . . . any additional ideas you might have to solve for this conundrum would be AWESOME!
Lisa and Frank
No Tow Car
Two Cats
05-29-2014, 06:53 PM
I'm going to try with a gripper this weekend. I tried with my bare hand while we were in Florida and it did not budge it.
05-29-2014, 10:12 PM
This type of light is a real PITA. I broke the lens on one of these trying to get the cover off to replace the bulb. I have 7 of these lights and have so far replaced 5 with different lights. I never could get the lens/bezel off any of these darn lights. Very frustrating
Ray Fenner
08 373DS
08 HHR Dingy
05-29-2014, 10:24 PM
If they break, looks like new lights all around..........Hate to be somewhere and really need the light and have it burn out and not be able to replace it.
Deb and Phil
Anna Belle
2016 Toyota Tundra
2011 Greywolf 26rl
06-03-2014, 07:54 PM
Great. More designed obsolescence.
What kind of lights did you replace them with? We were thinking of putting in LEDs instead of the halogens.
Lisa and Frank
No Tow Car
Two Cats
06-03-2014, 11:12 PM
Tim & Lisa Trempert
The larger lights are the ones where the lens twists out. On the smaller lights the whole fixture (including the chrome ring) twists out. This is probably why it was siliconed in and broke.
Tim & Lisa
2011 Georgetown 350
06-08-2014, 09:32 AM
I have a 2011 360, no problem on this and ones over sofa the silver ring is the only part to move, turn counter clockwise and the both ring and glass come down, uses g4 style bulb 10w, has halogen in it. I replaced all with leds. Amazing how much less heat.
Logic will carry you from point A to point B. Imagination will carry you everywhere. "Albert Einstein". 2011 Georgetown 360, Bride of 45yrs, and 2014 Chev Equinox toad, what more could you ask for.
