You never told us what model you have so all I can do is suggest a few locations.
1. If you have a larger 38 ft model you need to remove the inside steps at your entry door with the round key. This is where the house batteries are also as well as the hydraulic system.
2. The next location (drivers side) as I have been told is behind the propane tank and may be covered with a black plastic cover.
3. This one you would have spotted already but the older models have them up front in the engine compartment/hood area.
Just an FYI.....after looking under my Georgetown when I was just inspecting things, I noticed the hydraulic lines were they ran through the hole in the frame rail to the jack were rubbing on the sharp edge of the hole. There was a nick already on one hose from this. The RV was only 4 months old. Suggest checking this. I used zip ties to pull back the hose to where it was not touching the frame.
2017 Georgetown GT3 31B3
N Little Rock AR
Inspections are good! I found the cables running to the emergency start switch on our 3051S pulled tight and rubbing against the vehicle frame. Forest River techs installed some protective covering at the rally last year. I also rerouted the wires on the Big Foot jacks that were hanging low and just asking to be snagged on something.
