Old 08-23-2010, 06:48 AM   #31
CLASS "A" Senior Member
cfsoistman's Avatar
I use the auto level if I'm on fairly level ground while I'm setting up other things but still rely on the manual to final level it. One place we went last year though confused the heck out the thing. It looked like it would almost lay over on it's side. That was the day I learned to use the manual only if the ground is a bit slopey. Is that a word?
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 08-24-2010, 10:25 PM   #32
jd-ford-hd's Avatar
It is when used here..!!!
"IF IT AINT GOT A MOTOR, I AINT INTERESTED"
jd-ford-hd is offline   Reply With Quote
Old 09-16-2010, 08:39 PM   #33
Mac
Could Someone Please Post a Picture of this Black Box?
I'm having trouble locating it.
Mac is offline   Reply With Quote
Old 09-16-2010, 10:10 PM   #34
Mine is under my entry steps in the coach, use the small round key to loosen the steps and there it is! I just got my 2011 350 and found mine to be fairly smooth and easy going when you hit the retract all button. First camping trip in it this weekend!
megaman07 is offline   Reply With Quote
Old 09-20-2010, 11:13 PM   #35
whitebb's Avatar
I have had this problem several times and also had the 12VDC power center replaced because circuit board went bad, and next time I had the problem I forgot to check both fuses, the one on frame was tripped, forgot the 15 amp fuse. called tech and found a honest one only cost $20.00 and a nice tip. Since the power goes through ignition switch (switch relay) and motor is not running to recharge battery, the cables gets real hot and then trips and blows fuse. He suggested I wait say 10 minutes between slides going in/out. Works fine doing this, also rewire the power to go through a new relay on emergency brake like the leveling jacks work. I probably will do this when I return to Houston this fall. This makes since because it also solves a problem of slides moving out when some bumps slides switches, also happened at a rest stop. Hope this helps.
whitebb is offline   Reply With Quote
