04-11-2016, 08:34 AM
#21
According to the Lippert Web site, the recall applies to steps manufactured between 5-25-2007 and 12-18-2014. Another site lists the part numbers involved in the recall: (128980; 164194; 165033; 165034; 165035; 165044; 168367; 171317; 171776; 173476; 234310).
2018 Berkshire 38A
04-11-2016, 09:51 AM
#22
I did, I have a 2011 Georgetown, it took Indian River RV about 45 minutes, I just took the notice to them, they fixed it in short order.
04-12-2016, 07:46 PM
#23
2013 GEORGETOWN 351 DS
Thank You for the information. Our stairs model # 164194 failed three times, within the first 6 months we owned our MH. Upon the 2nd failure I replaced the failed Main Bolt with a bolt from a Chevy Brake slide and it has lasted over 2 years no issues.
The most recent failure was last week while in Key West. This time it was the small double ball joint arm PART # 301701. This part is no longer available. I sure hope this recall replaces the entire stair drive or I am still stuck with a broken double ball joint arm.
I scheduled a service with the dealer we purchased from but they could not tell me what was included with this recall.
GRV
We love to Roam
2013 Georgetown 351 DSF
2017 Honda Civic
04-12-2016, 08:56 PM
#24
You have a triple step, as I do and the double ball joint arm is replaced by one without double ball joints. The entire drive is not replaced.
04-12-2016, 09:06 PM
#25
I received the recall notice and I have an Aviator Wright Flyer without electric steps. Go Figure!
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
04-13-2016, 07:22 AM
#26
Do you know what the part # is for this replacement arm, as it appears I am stuck with the Lippert stairs....
GRV
We love to Roam
2017 Honda Civic
04-13-2016, 09:42 AM
#27
Originally Posted by ck101999
Yes it center bolt , my has been shop a over month waiting on parts . They will not give you new step. I have this issue from day one from new coach, it broken 5 to 6 times . So good luck .
Forest river gave me a new step. I'm sure they don't want to do it for everyone due to cost.
04-13-2016, 09:53 AM
#28
Don't know what the part number is but as said it will be installed as part of the recall kit for your steps.
04-14-2016, 07:41 PM
#29
I finally crawled under the MH and looked at the step, well it was all corroded and stuck, some lubrication spray and then some grease and now it works, it will have to be removed and either cleaned and painted, or replaced if too far gone
Originally Posted by hammer55
not sure but my single step might not be covered, got the recall notice, but went out day before yesterday and it isn't working, I can hear the mechanism moving but step is not, so I am going to have to build up the strength to crawl under there to see what is wrong, really loving all the problems
Mark & Annie
2014 COACHMEN PURSUIT 27 KB
Modesto, Central California
05-25-2016, 02:04 PM
#30
Steps are junk
# 1: 2010 G/town has already broken the heim joint (no one knows what to do) drilled it out and placed a hardened bolt !
#2: Then tapered bolt thru gear broke and local dlr. had one............ Bad product, so we use handmade step outside rather than incur more failures!!! Hurts when you step & fall due to cheap product.
05-30-2016, 07:56 PM
#31
After the steps not opening, and injuring my knee, Randy at Forest River contacted Lippert, and had the recall parts sent to my service tech. Great service on both companies parts. One more item checked off the list.
