Old 08-08-2012, 09:26 PM   #1
Living Room Lights
Mysteriously we now have none of the living room lights working. Last night everything was fine, this morning none of the lights work. I checked the breakers and they are all fine. I haven't checked the fuse but I wanted to ask this group if there is anything else I should check. I have reset the GFI in the bathroom just in case that had anything to do with it and it didn't fix the problem.
Any suggestions???
georgetown50 is offline   Reply With Quote
Old 08-08-2012, 09:46 PM   #2
2Susan's Avatar
Do you have a rocker switch near the door that controls the living room lights? Once that is on, they can individually be switched on and off. I suppose it's so you can flip on lights as you enter. I've turned off the lights individually at night and then the next day coming back to a dark rv tried the rocker switch and nothing happens. If your rocker switch is off the individual lights won't work.
2011 Georgetown 320DS new June 2010
days camped in 2010: 61
days camped in 2011: 37 (up to Aug 1st)
2Susan is offline   Reply With Quote
Old 08-08-2012, 09:47 PM   #3
VinceU's Avatar
Any suggestions???
You're checking A/C circuits and the overhead lights are DC probably halogen bulbs. This will come from a fuse in the panel marked "ceiling fwd" or "lighting fwd" or close to that. Mine operated from a switch on the entrance wall which is a toggle switch. I would fool with that right after checking for a fuse. Operate it a few times and see if you can get it to engage. Mine is a 2012 but I know 11 are similar maybe earlier. Just checked a photo- mine are labled "15 amp LR lights" where LR are living room. Hope it helps. There are four fixtures in a row.
Old 08-08-2012, 09:48 PM   #4
I had the same problem, ended up all the living room lights (5 total) burnt out. Since replacing haven't had any problems.
concours14 is offline   Reply With Quote
Old 08-08-2012, 11:45 PM   #5
Lights out
Ok, I didn't think fuses went bad that often but in this case it seems it was the fuse. I took the bad one out and put in a good one and it worked. I had already played with the switch on the wall. Thanks to all who responded.
