Old 08-25-2012, 10:08 AM   #1
SemperFi3088's Avatar
Living room Toshiba TV Cable issues
Coax cable is connected underneath the rv and at the source on our site. Tv is only picking up the antena signal. Using the input select on the tv remote we have one option and it is: Ant/Cable. The switcher box in the compartment above the front passenger side is switched to cable. I switch it from cable back to antena ad the channel changes. Is this a park issue?
SemperFi3088 is offline   Reply With Quote
Old 08-25-2012, 10:40 AM   #2
Iggy's Avatar
I had the same problem on my 378 . The problem was at the plug inside the power compartment. The coax from the back of the plate was had not been stripped properly and it had a layer of material over the center conductor. I would check there first then from there to the switch box end of the coax.
Good luck and let us know what you find.
John
Old 08-25-2012, 10:54 AM   #3
Herk7769's Avatar
Make sure you have turned off the booster switch. Since you do get roof antenna, it is most likely ON. Turn OFF to switch to park cable.
HAM CALLSIGN - KC3FFW
Old 08-25-2012, 11:11 AM   #4
Iggy's Avatar
Great point Herk. Forgot to mention the obvious.
No amp needed for park coax TV.
Old 08-25-2012, 01:04 PM   #5
Herk7769's Avatar
It is actually worse than "no amp needed for park coax;" If the amp power is ON it actually disconnects the park cable from the camper's distribution system.
Old 08-25-2012, 02:00 PM   #6
Ok is that the white wall socket that has coax input in the compartment above the passenger seat? If so it is set to "on".
Old 08-25-2012, 03:08 PM   #7
Herk7769's Avatar
Yes it is. Turn it OFF to use park Cable.
They also can look like this one.
Name:	Sandpiper Cable connections Bedroom.jpg
Old 08-25-2012, 03:47 PM   #8
how come that switch plate on mine has a 12v outlet in it?
trell is offline   Reply With Quote
Old 08-25-2012, 03:53 PM   #9
It's off now. I still only get channels 2 through 11. ARGH!!!
Old 08-25-2012, 04:32 PM   #10
FIX'D!!! turned of the booster, check. Then I came out to the outdoor tv unit, it's a Vizo. So i was was messing around with the menu's and came across "scan for avail Chanel's" !!! It scanned and all the channels appeared.
THANKS for all the tips and advice. It's better to think out loud with fellow road hogs!!!
