Old 10-19-2015, 09:44 PM   #1
Location of converter/inverter
Thanks for all the help on my last concerns....i have gotten all this issues corrected and now i have another issue. I think my converter/inverter may be bad as some my issues were solved after external charging my batteries....unit was plugged in to elect...but batteries were very weak....so i feel i may have a converter/inverter issue.
-were is converter located
-how can i tell if its bad
2005 georgetown xL model 359
Wwaller
Wwaller is offline   Reply With Quote
Old 10-20-2015, 03:56 PM   #2
vakeel's Avatar
I don't know how much help this will be as I have a 2013 XL, or if anyone else has already responded (nothing shows on my phone/app) but in mine my inverter is on the outside, driver side, right above my propane tank. If by converter you mean what I think you mean, again in my model, that is on the outside, driver's side, all the way in the last compartment where my shore cable is located.
vakeel is offline   Reply With Quote
Old 10-20-2015, 06:30 PM   #3
siskom's Avatar
I have a 2014 and mine is on passenger side in small compartment that has a black plastic in front of it remove plastic and you will have access, if it is in same location. how you check it would be plug some a/c operated device into plug on side of it they usually come with one or two receptacles. on the input side all you need is a meter set for DC volts.
siskom is offline   Reply With Quote
cat, converter, inverter, location
