Old 11-26-2015, 09:55 AM   #11
One of the things I do is, dump a bottle of pine sol (1/2 gal) into the black and gray tanks before I travel from one campsite to the next. I dump my black tank and flush it at least once a week. I use lavender scent and it seems to clean the sensors very well.
Roger2650 is offline   Reply With Quote
Old 11-27-2015, 06:36 AM   #12
Well first off I can not tell you the location of the sensors, but the level will always matter, any liquid will find it's own level all the time.
Happy Camping
P/S all factory sensors are what they (spun in) which means the take a high-speed tool and "burn" the fiberglass with the sensor from friction of the spinning, and they are put in on a factory line somewhere in the plant and then taken to the install line to be installed in yours and all other coaches being built that day
B.Smith
2010 Cedar Creek Silverback 35ts
2001 GMC 2500HD w/ Allison & 8.1
silverback 35ts is offline   Reply With Quote
Old 11-27-2015, 08:06 AM   #13
360true's Avatar
Thanks all. The reason why I originally asked the question was to try to determine if the black water flush actually sprayed the sensors. On my 378 I don't think that they actually do. Seems like it ought to due to the very common problem of keeping stuff off them.
360true is offline   Reply With Quote
cat, location, tank
