Old 12-10-2010, 07:41 PM   #1
Location of Water Pump in Georgetown 357QS
Can someone let me know where the water pump is located in a 2009 Georgetown 357 QS?
Thanks,
Eric
EricBart is offline   Reply With Quote
Old 12-10-2010, 09:53 PM   #2
ronhanson's Avatar
Check in the compartment behind the rear passenger wheel where the water tank is. There is a black wall of plastic there. It's hidden behind it under the water tank. I ditched the plastic on mine.
Ron Hanson
2009 Georgetown 350TS (bunks)
400W solar, 440AH 6V GC2
2009 Ford Edge AWD Ltd towed
2011 Honda Fit Sport towed
ronhanson is offline   Reply With Quote
Old 12-11-2010, 11:23 AM   #3
Thanks for the tip, you were right on. I am removing the cover too, since this is where water seems to collect and I need access.
Old 12-12-2010, 01:40 PM   #4
kenandterry's Avatar
RON.......
Ours is a 2010 330TS (presently in stoarge 2 hours away) and I located our fresh water supply tank in the compartment behind the rear wheel on the passenger side behind a big black plastic false wall. I assume the wall is just in place to offer a bit of protection to the tank and associated hoese etc. I was looking for the tank for other reasons and never looked for other equipment in the same area. I'll look when I get it back and see if our pump is there too. Wondered where it might be!
kenandterry is offline   Reply With Quote
