Old 08-15-2015, 07:41 PM   #1
Loose wire
I have a 2007 Georgetown 359TS. Under the entry step, where the batteries are located, I was cleaning the topping up the batteries when I found a heavy gage green wire that was not connected to anything. I'm sure it needed to be connected, does anyone know if it is positive or a negative ground? Power in the MH is working so I'm not sure what it is for.
Hankster is offline   Reply With Quote
Old 08-16-2015, 06:31 AM   #2
Coach 350's Avatar
Usually color green wire is ground. I would try and follow to make sure.
Coach 350 is offline   Reply With Quote
Old 08-16-2015, 07:22 AM   #3
I would not make the assumption that green is ground. The rv industry does not seem to follow industry standards for color when it come to wiring. I would follow it to its source or try to measure resistance to the frame.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 08-16-2015, 07:39 AM   #4
BillMFl's Avatar
I have several unused wires hanging from a bundle of wiring in that area. Sometime harnesses are made up to be used for a variety of models and some wires aren't needed for all models. Everything works so I ignore the extras.
BillMFl is offline   Reply With Quote
Old 08-16-2015, 09:01 AM   #5
Tim & Lisa Trempert
X2
Tim & Lisa
2011 Georgetown 350
Trempert is offline   Reply With Quote
Old 08-17-2015, 10:59 AM   #6
Thank you for your replies. Because the wire appears to be ground, because the wire appears to run near the negative side of the batteries, and because it has a connector on it, I will attach it to the negative ground next time I am in the MH. Will let everyone know how I make out.
