Originally Posted by Homejames
I got everything to work. In case anyone else has this problem: On the 378T on the wall to the left of the 2 batteries their is a junction box that has written on it 120A. There is a little red plunger sticking out that disconnects the hydralic motor. To the left of the red plunger is a black throw (less than 1 inch apart) switch which is the reset. I had to pop the cover to see this (hard to read) when I found no juice was coming through the box. I turned the reset and I am back in business.
I did add water to the batteries yesterday and must have hit the red plunger.
Glad you found the tripped circuit breaker.
Now you do know you shouldn't use the hydralic pump unless you are hooked up to shore power or positive you have 100% fully charged batteries.
The tripped breaker means that you has high amperage at the pump motor which is the only reason for the CB will trip. Low voltage
