Old 06-09-2019, 07:51 PM   #1
Low cold water pressure
We have a 2018 Georgetown and we havenít used it for a couple months so we took it out this weekend just for a couple of days. When we set up at the campground we found out we had NO cold water at the kitchen sink (hot seems ok) and NO water to the toilet. Other water supplies seem normal ( bathroom sink, inside shower & outside shower). We have the same symptoms if weíre hooked to city water or pumping from the fresh water tank.
Any suggestions??
o2beme
sbo2beme is offline   Reply With Quote
Old 06-10-2019, 09:45 AM   #2
SeaDog's Avatar
Welcome to the forum its a great place to get your questions answered. I suspect you have debris in those lines and will need to take the connections apart from the valve and check and flush out.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 06-10-2019, 06:06 PM   #3
Thanks for your reply. You are right. Today I removed the toilet (had to in order to get to the valve) and the screen right there at the inlet was packed with debris (looked like calcium deposits). Cleaned the screen, flushed the line and now it works fine. Same with the kitchen sink. The blockage was not in the screen but must have been in the valve itself. I had to disconnect the line blow it out from the faucet down. Good water flow all around now. Not sure what causes this stuff or how to prevent it. I ALWAYS use a filter on the hose and have another filter permanently installed on the coach.
Thanks again
o2beme
pressure, water
