Old 12-02-2011, 01:29 AM   #1
Low Point Drain
Have not had this happen before, but the water in the fresh water tank would not drain out unless the water pump is running? It worked fine the last couple of years, its like its not getting vented air to drain out.?? I must be missing something, any helps out there? Its a 08 Georgtown 374TS.
Gary
Ggantilla is offline   Reply With Quote
Old 12-02-2011, 01:38 AM   #2
Sounds like a clogged vent line. Did you check the vent line for blockage?
Thew pump may suck hard enough to get air by the blockage.
Just a guess.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 12-03-2011, 11:40 AM   #3
Not yet, but that must be it. Thx
Old 12-05-2011, 01:24 PM   #4
CLASS "A" Senior Member
cfsoistman's Avatar
This may sound stupid but take the vent hose and blow through it. The sloshing of the water when you drive down the road gets water into the line which is trapped. My tank drained very slow until I did this and afterwards it drained much better.
There are posts on here about syphoning fresh water tanks while driving. This is the remaining water in the trapped line causing the slow draining tank.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is offline   Reply With Quote
Old 12-05-2011, 01:32 PM   #5
Thanks, will do that.
Its back at the dealer, after getting the lippert steps repaired 3 times, they were finally working great, and had it back at the dealer for some warranty generator issues, and they managed to run into the steps while in the shop, and nearly tore them off!!!!! absolutely unreal!
