Old 04-14-2012, 10:26 AM   #1
low water pressure
Hello all, whenever I turn water on, pressure is fine for about 30 seconds but gets less and less.
Checked water inlet, screen was a little plugged, but didn't make any differance.
I removed the psi regulator from the hose bib, helped a little but not much.
I have never flushed the HW heater?? Could that be it? Pressure is not great at supply, but I would think good enough.
All the faucets seem to be the same, including shower and outside shower hose.
08 Georgetown.
Ggantilla is offline   Reply With Quote
Old 04-14-2012, 10:47 AM   #2
TURBS's Avatar
Have you changed your water filter?
Old 04-14-2012, 02:15 PM   #3
Iggy's Avatar
X2 Clean water filter in canister.
Old 04-14-2012, 02:37 PM   #4
I recently changed water filter in the canister, so took it out and everything works great without the filter in. The old filter was the regular one in the canister which was hallow in the middle. The new one I got from CW, Culligan brand is not hallow in the middle, the plastic inserts on the end appear to restrict the water flow, sounds crazy I know.
I put one of the inline water filters on and left the canister one out, is that OK?
Old 04-14-2012, 03:12 PM   #5
Triguy's Avatar
Its fine. I'm currently running with an inline filter and no filter inside. Just lazy and didn't want to pay for a water pur replacement filter But, while researching filters, I found some that listed a higher flow. I'd suggest you look into those filters. I'll likely but from this company if I add one again. http://www.rvwaterfilterstore.com/RCCarbonCartridge.htm
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 04-14-2012, 03:18 PM   #6
TURBS's Avatar
If you got one with the ends capped off then I believe you got the wrong one.
Old 04-14-2012, 11:02 PM   #7
That is the issue. Thx
Old 04-14-2012, 11:06 PM   #8
Iggy's Avatar
The filter I had in my FR Rockwood is one you can wash and clean then replace.
It caught the large particles and the mesh was white plastic like and not paper/
Old 04-14-2012, 11:09 PM   #9
TURBS's Avatar
Filter should have both ends open .
Was your original open both ends?
Old 04-15-2012, 08:41 AM   #10
Original did have open ends. CW had two on the shelf, one was white like the original, the other was a black or brown which I didn't really consider, but I bet it had open ends. Oh well, live and learn.
