Old 03-19-2016, 09:57 PM   #1
LP Gas Quick Connect Question
My rig came with an outside LP Quick Connect. I currently have a Weber Q200 series grill that I have had for a couple of years. Now that I have a way to power off of the coaches LP, I can't seem to figure out how to get Gas to the Weber grill.
Can it be done?
What other grills do you guys use?
Mickey Alberto
2016 Forest River Georgetown XL 350TS
Ford V-10 (5-Star Tuned)
cmalberto is offline   Reply With Quote
Old 03-20-2016, 05:33 AM   #2
Ford Idaho's Avatar
I am unsure if the Weber has a built on gas regulator.
IF the gas to the QD is regulated and the Weber is there may not be enough pressure for it to light.
Some have removed the regulator on the grill while some bypass the trailer regulator.
Old 03-20-2016, 06:02 AM   #3
nomad297's Avatar
You have to remove the regulator from the Weber and buy adapters to Connect your hose.
Bruce
Old 03-20-2016, 06:59 AM   #4
I just did it on my Q1000. "YouTube University", EZ Peezie....
(Full disclosure, I haven't been able to test it yet though. My GT gets delivered on Wednesday. Here are some pics of what my Q looks like)
Name:	ImageUploadedByForest River Forums1458474964.490477.jpg
Name:	ImageUploadedByForest River Forums1458474663.659467.jpg
ID:	102389Click image for larger version
Name:	ImageUploadedByForest River Forums1458474739.009494.jpg
Melvinson404 is offline   Reply With Quote
Old 03-20-2016, 09:57 AM   #5
Attachment 102391
Attachment 102389Attachment 102390
I need to go get my old regulator out of the trash. Just replaced last week.
Great pics. I will check out the vid. Looks perfect.
Old 03-20-2016, 10:22 AM   #6
I don't believe you'll need the original regulator that came on it. It's in my pic just to show that it was removed. The YouTube video I based my mod on was "Weber Q1200 High Pressure to Low Pressure RV Conversion". Good luck.....
Old 03-20-2016, 11:49 AM   #7
gas quick connect
was at the Toronto RV show a couple of weeks ago & the rep at the Weber display said that an ez way to know if you can hook your grill to the RV gas supply directly is if the bbq has one control knob at the point where the gas line connects you will need a special adapter but if your grill has the knobs located in the front of the grill & gas connects at side you can connect to rv gas supply only with the use of a hose. Hope this helps.
jjrver is offline   Reply With Quote
Old 03-20-2016, 12:11 PM   #8
jeff64's Avatar
Once you get the regultror off you will have to get the fittings to go from 1/8 NPT to 1/4NPT the hoses and quick connect male and the hose. There are plenty of threads on this site/ subject
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 03-20-2016, 12:12 PM   #9
Dahagen
On my Q1000 I just got a hose that has the quick disconnect on one end and a threaded end that fits into the place where the small bottles of propane go. Since the quick disconnect on the RV end is before the regulator, I had to leave the factory regulator on the Q1000.
dahagen is online now   Reply With Quote
Old 03-20-2016, 01:24 PM   #10
Boondocking Only
ddbck's Avatar
Only use the 1 regulator, (the campers). I put a quick connect on my Camp Chef Yukon, it works great. URL=http://s651.photobucket.com/user/kramer88/media/009_zpscigwiftp.jpg.html][/URL]
ddbck is offline   Reply With Quote
gas
