Old 09-19-2016, 03:10 PM   #1
LP refill
Always refilled at a place close to home and they always use the bleeder valve
to tell when full. So this time a new young guy decided to auto fill , I insisted
on useing the bleeder but he said they use auto now. So long story short he over filled my tank ,he didn't look at guage it fill out of sight , I didn't notice
till I was going to winterized . Now I have to go back and have them bleed it down. Auto fill doesn't always work. Operaterator should of noticed the guage.
Just venting ??
Don
Georgetown 335DS 2013
Toad 2010 Ford Fusion
Donlock is offline   Reply With Quote
Old 09-19-2016, 07:03 PM   #2
Tim & Lisa Trempert
How can you tell if it's overfilled?
Tim & Lisa
2011 Georgetown 350
Trempert is offline   Reply With Quote
Old 09-19-2016, 08:34 PM   #3
campingbaba's Avatar
The only correct way to fill any propane is by the bleeder . The gauges are not always correct . I would be carefull on how anyone would bleed of the extra liquid . If it was mine I would start the furnace and burn it of . Depending on the BTU 's of the furnace . For example if it is a 50,000 BTU in will burn approx 1/2 gallon per hour .
campingbaba is offline   Reply With Quote
Old 09-19-2016, 08:37 PM   #4
Flybob's Avatar
Run the stove for a while.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 09-19-2016, 08:43 PM   #5
Deleted
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
2016 Nights Camped = 46
Old 09-19-2016, 09:03 PM   #6
Bluepill's Avatar
Page 49 & 50 of this manual states the proper ways to fill FIXED (Not Portable) RV tanks:
http://www.propanecouncil.org/upload...g%20Manual.pdf
Note in step 6 that "Full" may be indicated by venting mist OR auto shut-off by the OPD. Either method is acceptable.
Following all listed precautions, you can check for excessively high level by opening the Fixed Maximum Liquid Level Gauge.
2008 Itasca Meridian 37H
Bluepill is online now   Reply With Quote
Old 09-19-2016, 11:05 PM   #7
When you can't see red needle on guage and when it is way past full.
Don
Old 09-20-2016, 12:44 PM   #8
Iggy's Avatar
This is why I never allow my dealer to fill beyond 3/4 of a tank mark.
2012 Georgetown XL - 378TS 49,900 miles
(2013 - 98 days) (2014 - 117 days) (2015 - 67 days) (2016 - 111 days) (2017 Est 115)
USAF Retired - MSgt
