Old 03-09-2015, 10:10 PM   #1
WDK
WDK's Avatar
LP Regulator replacement.
I am replacing my leaking 524AS LP regulator with the exact same model. Its output is suppose to be 11 inches water column. My question is since its not stamped on the regulator as certified what is to say that it does not need adjusting and how can you confirm?? I have since checked that each appliance i.e. the stove, frig, and heater and they each have their own regulator and of course their output is contingent on the input so again should I just take it for granted and install it or is there a proper way to check it?
WDK
WDK is offline   Reply With Quote
Old 03-09-2015, 10:27 PM   #2
Crockett's Avatar
the proper way would be a "slack tube" on a port of the reg. 11 to 12" flowing. my guess is no one checks a new one. Id just roll with it...
Crockett is offline   Reply With Quote
Old 03-10-2015, 09:09 AM   #3
WDK
WDK's Avatar
.....as everything worked before I pulled it out, putting a new one without testing its output should still narrow any problems I might have and it's much simpler of course than say like putting in an untested alternator.....too much trouble to find out that it does not work.
WDK
Old 03-10-2015, 07:27 PM   #4
WDK
WDK's Avatar
Is that heater just passed the regulator there to warm the propane from its liquid state before sending it on too the other appliances?
WDK
Old 03-10-2015, 07:38 PM   #5
Crockett's Avatar
WDK
the LP should be a vapor as it boils off the liquid in the tank. there should be only vapor in the line.
Old 03-10-2015, 07:44 PM   #6
WDK
WDK's Avatar
Thank you.....I am asking because Amazon did not send the regulator I ordered which was the 542AS but instead a replacement, model number 6080 that vents out the side right at that heater and it looks like I have to resign myself to sending it back.
WDK
Old 03-10-2015, 07:47 PM   #7
Crockett's Avatar
vents just need to be within 45 degrees of down. nothing vents out the vent really. just there to allow atmospheric pressure to diaphram...
Old 03-10-2015, 07:52 PM   #8
WDK
WDK's Avatar
Name:	ImageUploadedByForest River Forums1426035112.318446.jpg
Old 03-10-2015, 08:12 PM   #9
Crockett's Avatar
ty for the pics...your old reg is a horizontal reg and 160,000 btu. the new reg is a vertical reg and 80,000 btu. if its going on a motorhome tank in a horizontal position then you should have another reg. i would not worry too much about the output. 80,000 should be ok unless you have a lp genset or something...
Old 03-10-2015, 08:12 PM   #10
WDK
WDK's Avatar
....the one they sent vents to the right....and yes I questioned it because all of the instructions say that it should vent down and this one I enclosed in the earlier picture does not fit the Georgetown application.
WDKClick image for larger version
Name:	ImageUploadedByForest River Forums1426036369.145435.jpg
Old 03-10-2015, 09:39 PM   #11
Crockett's Avatar
yeah, your vent is 90 degrees off...Sorry
Old 03-10-2015, 11:32 PM   #12
WDK
WDK's Avatar
Yeah, that was not what I ordered so it looks like I will have to look for one the old fashioned way. Thank you.
WDK
replacement
