04-04-2014, 10:21 PM
Mature Citizen
Magic Chef Microwave
I have a 2013 Georgetown XL 378 and the microwave just quit. It is less then a year old and probably has only 20 hours max on it. The outlet has power. I remember a thread about this in the past but can't find it. Any ideas? I am a month from being able to take it to the dealer.
Darlene, Ralph and Pippin
LTC (USA Retired), W7TLD
2023 - 199 days, 6966 miles
2013 - 2019 - 901 days & 37171 miles
2013 Georgetown XL 378 TS, 2014 Honda CRV
04-04-2014, 10:32 PM
Do you get anything on the led screen?
If you do and it just won't run check the door switch.
If it is broken or not latching it will not let the microwave to run.
If you are really handy and the switch is good you may have to take it down and check the internal fuse. But remember it blew for a reason and the magnetron may be bad.
Be careful.
P.S.
If you have to take it down you must remove the piece of panel at the top to get to the 2 screws that will release it from the top cabinet and it should swing down from the wall bracket.
If it is still under the one year Forest River warranty I would take it to the dealer but notify Forest River via email ASAP to get it on your record.
This will make it easier for the dealer to replace.
Is Snoqualmie Falls still frozen?
04-05-2014, 07:06 AM
Just Love to Camp
Had the same thing happen. FR replaced under warranty.
Also you might want to check by opening un and make sure the main plug hasn't come unplugged from bouncing up and down the road. Happen to a microwave one time. Dh had it fixed in about 15 minutes.
Camped 54 Night 2012
XLR Thunderbolt 386*12
" Bertha The LeadSled" is her name
2012 F450
Virginia
04-05-2014, 07:23 AM
We've had this happen several times but its totally random. All the power goes out on it (while cooking). No front LCD panel or the likes. Checked fuses and cords. Then it just magically turns on randomly later like 20 to 40 mins later. We couldn't reproduce nor could FR so they wouldn't swap mine out. :-(
06-16-2014, 09:06 PM
It's a faulty internal electrical issues. When closing the cupboard door above, letting it slam etc breaks the internal electrical thingy. Ours was repaired under warranty and this year it happened again. Part is about $130 installed after you take it out of the RV.
06-16-2014, 09:22 PM
If it is the Over The Range (OTR) model with light and fan, they have thermal protectors that shut them down when the temp gets too high. Supposedly to protect the unit when the cooktop is on full and overheats the area.
My '05 had a 22" Magic Chef OTR that failed due to low voltage and that size unit is no longer produced. I installed a GE under counter unit and now all is well.
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
06-17-2014, 11:06 PM
I had something similar happen and the symptoms sound about the same. It was a magnetron failure, and they have a 10 year warranty. The microwave company covered all the expense.
Ron
07-08-2014, 09:30 PM
Forget the Magic Chef and get a GE Convection Microwave fits right in. Take to old mounting bracket to mark the new bracket so you will use the same mounting holes on the wall. Use the template supplied with the new oven to make sure you mount the bolts that drop down through the shelf correctly. It will take two folks to lift the new oven into place.
We love ours, we never use the gas oven, it's our bread box now.
11-16-2014, 12:14 PM
We r camping right now and had this happen. Waiting 20-40 minutes for it to come back on sounds a lot better than running out, buying a GE and installing it following the included template. 😊 Any other suggestions besides those two options would be greatly appreciated as I think we r passed 40 minutes and no GE dealers around.
2013 Georgetown XL 377TS
11-16-2014, 03:20 PM
Please take a look at this post about a recall on the microwave and read if it is one that you have.
http://www.forestriverforums.com/for...all-69808.html
11-16-2014, 08:49 PM
Thanks Iggy. Mine is not a convection oven. I have an OTR Magic Chef.
11-16-2014, 09:40 PM
Originally Posted by Iggy
When I click on your link, it takes me to a post about laundry..... ??
2013 Georgetown XL 350
Bunkhouse
2002 F250 4X4 CC
2012 Jeep Liberty
11-16-2014, 09:49 PM
Bunkhouse
2002 F250 4X4 CC
2012 Jeep Liberty
Or you can search the title
2013-2014 Microwave/Convection Oven Recall
Try this again
11-16-2014, 11:22 PM
Sometimes you can disconnect the power to the M/W by plug or by circuit breaker for 30 seconds. It may reset the electronics and back online. Worked for me twice.
11-17-2014, 12:59 AM
I just tried that. Unfortunately it did not work, but it was worth a shot. Thanks.
11-18-2014, 11:22 PM
One last keep it home idea. Normally the oven will have a glass 15 or 20 amp glass fuse just under the outer casing where the power cord enters. Saves oven from spike currents. Pain to reach but worth the cancelled trip to shop.
11-19-2014, 06:04 PM
Thanks. I unplugged my microwave and plugged in my phone charger in the same outlet just to see if the outlet works and I had no power. So I am hoping it's just the circuit breaker or fuse that powers the outlet. Problem is I have no clue where that may be. Any ideas where I may be able to find it?
Come to think of it besides a bank of fuses under the steering wheel, and a few fuses and circuit breakers under the entry steps where my batteries are, I have not been able to find any other breakers or fuses in this thing.
11-21-2014, 09:19 AM
MW pwr. supply
There is a panel with hinged cover some where in the bdrm or kitchen contains the shore power brkr supply and all a/c loads. Mounted low in has the keys to your castle for all power distribution. Yes your MW power is there also.
11-21-2014, 04:29 PM
Thanks. Next time I get a chance to go to storage I'll check it out.
11-21-2014, 05:40 PM
Retired Ford Tech
Our 2008 GT has the same issue as yours. We found out it only happens when we were on 30 amp, not 50 amp. Don't know why,but when we're on 50 amp it's fine. Maybe the voltage drop under a load ?
