Old 10-16-2016, 10:17 AM   #11
Iggy's Avatar
Originally Posted by bubbles View Post
I thought that is what I said.
Your answer was OK but they needed to know where to buy them, what CC10 meant and you didn't uploaded any pictures.
Here is the filter housing I have.
2012 Georgetown XL - 378TS
Iggy is online now   Reply With Quote
Old 10-16-2016, 10:38 AM   #12
Iggy's Avatar
Originally Posted by RJJ View Post
The 2015's had KW1 filters by waterpur, don't use the standard filters unless you change out the housing unit first. If it looks like this you have an FR1 housing and a KW1 filter. Attachment 123100
Notice the difference in the top of the filter it has a male section with an o ring. The canister is not just threads like a standard filter, but has notches and kind of clicks into place. I didn't like this set up and read on numerous failures people had with this system, that's why I changed mine out. Plus I can now get filters pretty much anywhere.
2015 Georgetown 329DS
2014 Chevy Equinox
I guess FR decides to go with another system in 2015.
Is that the type they are still installing in the 2016 and 2017's?
Old 10-16-2016, 01:48 PM   #13
RJJ
Sorry Iggy, not sure when they started or if/when they stopped using this filter.
2014 Chevy Equinox
RJJ is offline   Reply With Quote
Old 10-17-2016, 09:39 AM   #14
360true's Avatar
From an older thread, it was suggested that I swap out the housing for a much less costly setup. Here is what was suggested and I did on my 2014 378
Pentek P5 Water Filter* @* $3.65
Pentek 158622 1/2" 3G Slim Line 10" Clear Housing* @* $16.78
Pentek 3G SL Bracket Kit for Slim Line Housings* @* $6.74
From discountfilterstore.com
Bracket fit existing holes, filters less than $4.
360true is offline   Reply With Quote
Old 10-17-2016, 10:31 AM   #15
NCCoachMan's Avatar
Uh, I got a 2016 in June and it has the FR1 type system in it.
2016 Georgetown XL 369DS
Lake Norman, North Carolina
NCCoachMan is offline   Reply With Quote
Old 10-17-2016, 10:54 AM   #16
lgray's Avatar
This may help
The KW1 Water Filter Myth
lgray is offline   Reply With Quote
Old 10-17-2016, 11:59 AM   #17
NCCoachMan's Avatar
Very helpful conversation. Thanks for posting!
water, water filter
