Old 10-15-2016, 04:33 PM   #1
Main water filter
We have a 2015 XL 377 and need to change the main water filter, but can't find any info on what make our model to buy. Can anyone tell me where to look or what replacement to buy? Thanks Richard
revflyer is offline   Reply With Quote
Old 10-15-2016, 05:28 PM   #2
RJJ
Mine was on a sticker on the housing, KW1 I think it was. Fairly pricey for a water filter, so I took out the Filter cartridge setup that came with the unit and put in a standard canister.
2015 Georgetown 329DS
2014 Chevy Equinox
RJJ is offline   Reply With Quote
Old 10-15-2016, 05:36 PM   #3
X2
What RJJ said
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
Davidceder is offline   Reply With Quote
Old 10-15-2016, 06:10 PM   #4
bubbles's Avatar
The GT does not use the KW1 filter. It uses a standard 10 inch CC10 type filter available everywhere for about $8 for two.
Old 10-15-2016, 06:31 PM   #5
RJJ
Mine new was KW1 not standard.
2014 Chevy Equinox
Old 10-15-2016, 08:11 PM   #6
Iggy's Avatar
Walmart package of 2 filters with the carbon wrap. $6 or $7
They are for Whirlpool, GE, Culligan, DuPont, Omni water filters.
5 micron and good for 15,000 gallons.
You must get the filters with the hole on the top and bottom or you will not get water flow.
ID:	123072   Click image for larger version
Name:	WjI5dlphUzUzWVd4dFlYSjBhVzFoWjJWekxtTnZiUzlwTDNBdk1EQXZOemd2TnpRdk1qQXZOVEl2TURBM09EYzBNakExTWpR.jpg
2012 Georgetown XL - 378TS
Old 10-15-2016, 10:58 PM   #7
ramair's Avatar
X2 Walmart is what I use and works just as good.
Andrew & Donna Reyes
2012 Georgetown 378XL
2015 Ford Taurus
Our Baby Dachshund
Cammie
ramair is offline   Reply With Quote
Old 10-16-2016, 05:35 AM   #8
bubbles's Avatar
I thought that is what I said.
Old 10-16-2016, 06:45 AM   #9
Uwntgess123's Avatar
My 2015 377 uses kw1
Uwntgess123 is offline   Reply With Quote
Old 10-16-2016, 09:05 AM   #10
RJJ
The 2015's had KW1 filters by waterpur, don't use the standard filters unless you change out the housing unit first. If it looks like this you have an FR1 housing and a KW1 filter. Click image for larger version
Name:	ImageUploadedByForest River Forums1476626419.258140.jpg
Notice the difference in the top of the filter it has a male section with an o ring. The canister is not just threads like a standard filter, but has notches and kind of clicks into place. I didn't like this set up and read on numerous failures people had with this system, that's why I changed mine out. Plus I can now get filters pretty much anywhere.
2014 Chevy Equinox
water, water filter
