Old 05-17-2015, 09:22 AM   #11
Originally Posted by gljurczyk View Post
...By your logic then just hook up the plus and minus and use your negative from the first battery to ground....
Old 05-17-2015, 10:00 AM   #12
Witch Doctor's Avatar
I have no dog in this. That's the only way that I would charge same as hooking the batteries up 1) with one battery you hook pos to trailer and neg. to ground. In parallel you hook pos to pos neg from the first bat to the second battery then from the second battery you go to ground. You charge the same way. That is the way I do it and will keep doing it. My batteries are 4 years old cheapo interstate. Had the 30 amp off for 48 hrs this week and the meter at my panel read 12.7. Gees must be doing something right. I also have a load meter, put that on and tested after 48 it show green, bought it at harbour freight. This is my opinion on how to charge my batteries hooked in parallel
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Witch Doctor is online now   Reply With Quote
Old 05-17-2015, 11:04 AM   #13
Tiger42's Avatar
Iggy, that is what I wanted to do use one tender to maintain 2 battries, just wasn't sure how to hook ir up.
Thanks guys for the input.
Tiger42 is offline   Reply With Quote
Old 05-17-2015, 11:32 AM   #14
bend302's Avatar
I use a battery tender while my Georgetown is in storage (2 12 V batteries). And I hook the positive to the front battery and the negative to the rear most connection. Works great.
On my unit, a 2005, I must not have a very smart on board charger because I boiled my old batteries dry in just a few days. Ended up shortening their life. Now use the battery tender on the newer ones.
When I go to Florida in the winter, I leave my van in the storage unit with the battery tender to keep that battery alive until I return.
I also put a battery tender on the battery on my golf cart over the winter.
I am a big fan of battery tenders.
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
bend302 is offline   Reply With Quote
Old 05-17-2015, 03:56 PM   #15
Speaking of batteries, my 2014 Georgetown has two coach batteries (can't insert picture right now). I am trying to determine if they are sealed, maintenance-free or is there a way to open and check the water level. Anyone?
Donamac is offline   Reply With Quote
Old 05-17-2015, 04:29 PM   #16
If you are going to charge two batteries in Parallel. Then you hook the positive to the first battery and the negative to the second battery. Do not put the charger on only one battery.....:
This is actually the correct way to hook up to multiple batteries in parallel.
Of all the things I've lost in my life the thing I miss the most is my mind!
prairiecamper is offline   Reply With Quote
Old 05-17-2015, 07:35 PM   #17
Krazymace's Avatar
Originally Posted by WDK View Post
If your going to be plugging in a charger, or battery tender unless it's solar, why not just plug in your coach and make sure your battery disconnect switch is in and the charger on your coach will charge the batteries. If it's a newer coach the smart charger is the best thing for your batteries.
This is what I do. Why make it more complicated?
Krazymace is offline   Reply With Quote
