Old 05-16-2015, 09:27 AM   #1
Tiger42's Avatar
Maintaining batteries
Will a 1.5 amp charger maintain 2 batteries tied together while the coach is not in use?
If so what is the procedure to hook it up?
Tiger42 is offline   Reply With Quote
Old 05-16-2015, 11:00 AM   #2
Tim & Lisa Trempert
Assuming they are in parallel (most likely since they are probably 12V batteries) they act like one battery. Just hook up the charger and you are good to go. Check the water level if you are going to charge them for long periods of time as it could evaporate more quickly while you are charging.
Tim & Lisa
2011 Georgetown 350
Trempert is offline   Reply With Quote
Old 05-16-2015, 11:09 AM   #3
Limey's Avatar
Don't use a charger to maintain batteries, it will probably fry them. You need a battery maintainer such as the brand "Battery Tender".
Limey is offline   Reply With Quote
Old 05-16-2015, 01:19 PM   #4
Iggy's Avatar
A 1.5 amp charger will not burn up two 850 amp hour batteries.
That sounds like he has a Battery Tender.
It will maintain them but will not do any damage.
Old 05-16-2015, 02:08 PM   #5
WDK
WDK's Avatar
If your going to be plugging in a charger, or battery tender unless it's solar, why not just plug in your coach and make sure your battery disconnect switch is in and the charger on your coach will charge the batteries. If it's a newer coach the smart charger is the best thing for your batteries.
WDK
WDK is offline   Reply With Quote
Old 05-16-2015, 02:35 PM   #6
Assume two things; 1. your referring to a trickle charger being 1.5 amps 2. Your house batteries are already at full charge, prior to the maintain charging your asking about.Your good to go then.
Also, over the long haul, you will not "use up" the fixed life as fast that all electronic gizmos have, like the more expensive on board unit. Just sayin'
Old 05-16-2015, 02:35 PM   #7
Witch Doctor's Avatar
If you are going to charge two batteries in Parallel. Then you hook the positive to the first battery and the negative to the second battery. Do not put the charger on only one battery.....:
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 05-17-2015, 08:44 AM   #8
Tim & Lisa Trempert
It doesn't matter. The batteries are not smart enough to know what end of the cable you hooked the charger to.
Tim & Lisa
2011 Georgetown 350
Old 05-17-2015, 08:53 AM   #9
X2, but it doesn't hurt one way or the other.
Old 05-17-2015, 09:17 AM   #10
According to living on 12 volt that is the way to equalize the charge. But people can do what they want. I'm not buying there batteries. By your logic then just hook up the plus and minus and use your negative from the first battery to ground. That is what you are doing by charging only one battery. It's just my answer to the OP right or wrong.....
battery
