Old 12-11-2017, 11:44 AM   #1
Tbonz's Avatar
Messy batteries
How do I stop this from happening? AGM batteries?Click image for larger version
2017 Georgetown 329S
Toad 2015 Toyota Tacoma
Tbonz is offline   Reply With Quote
Old 12-11-2017, 12:03 PM   #2
Flybob's Avatar
Check electrolyte levels. Overcharging can also cause this.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 12-11-2017, 12:15 PM   #3
D W
D W's Avatar
Originally Posted by Tbonz View Post
How do I stop this from happening? AGM batteries?Attachment 158106
That is caused by the batteries off-gassing and the condensed particles reacting on the metal. While all lead-acid batteries will off-gas some, a battery that is constantly being overcharged will actually boil out. Additionally, a battery that is allowed to "sulphate" (go into deep discharge for long periods), will also cause this situation.
1. Check for overcharging condition. Correct as required.
2. Remove the batteries and hardware and clean vigorously with baking soda and water, including compartments. Allow to dry completely.
3. Thoroughly clean-up all hardware (remove corrosion), and repaint hold-down hardware with a good coat of oil based enamel paint. Wire brush terminals and connections and coat with Dow 5-Compound.
2016 Salem 27RKSS
D W is offline   Reply With Quote
Old 12-11-2017, 12:50 PM   #4
Iwannacamp's Avatar
It can also be a weak cell in the battery causing it to boil and gas-off. A battery that is "exercised"...used very hard.... rode hard and put up wet can cause the gassing as well. I hot charger and a low battery(as mentioned) will gas more. You can buy corrosion inhibitor spray and paint the stuff, but it is messy.
If it is just the one battery... I am going with weak battery. YMMV
2017 Puma 297RLSS
Old 12-11-2017, 12:58 PM   #5
Tbonz's Avatar
I have a Progressive Dynamics with the charge wizard. A little nervous of doing too much water in there to clean this mess,there are a lot of electrical connections in there. Soon as it warms up I will get busy and clean this mess up. Thanks for all the responses.
Old 12-11-2017, 03:34 PM   #6
Broken Toe
Cowracer's Avatar
A can of Coke will clean that right up.
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
"Camper" 2016
Rockwood Signature Ultralite 8329ss
"Casper" 2017 Ram 2500 Laramie Diesel
..ProPride 3P Hitch - "Yeah. It's worth it."
Cowracer is offline   Reply With Quote
Old 12-11-2017, 09:19 PM   #7
Mnflyboy's Avatar
As has been mentioned above....check water levels in batteries. Do not overfill these batteries or this can happen, too.
Jaye (Mn)
Jaye & Cindy
2007 Georgetown 349 XL
Mnflyboy is offline   Reply With Quote
Old 12-12-2017, 12:38 AM   #8
Always Learning
I’m confused by the mention of checking water levels... I thought AGMs were sealed? Or am I mistaken?
Old 12-12-2017, 02:08 AM   #9
He doesn't have AGMs.
babock is offline   Reply With Quote
Old 12-12-2017, 09:45 AM   #10
Agreed, from the photos shown, they are not AGM. I will bet if you remove the fill caps they will be low on water. They should be filled to the collars in the fill tubes with distilled water, this should help if u have not already fried them.
Jim G is offline   Reply With Quote
Old 12-12-2017, 10:19 AM   #11
SlowrideHD's Avatar
I think he is asking if switching to AGM batteries will solve this.
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
USS Pyro AE-24 WestPac MM2 '71-'75
SlowrideHD is offline   Reply With Quote
Old 12-12-2017, 10:40 AM   #12
Always Learning
I see that now. Thanks guys.
batteries
