Old 09-22-2018, 09:18 AM   #1
Microwave not working with Generator on.
A. Everything in my 335DS works with Generator on.
B. I Checked to see if the Microwave was plugged in. It was.
C. I Checked the circuit breaker. It was not tripped.
D. Tried plugging something else into the outlet and it did not work.
E. Is this a simple as pulling the outlet out maybe a wire loose. Or will I need a new oulet.
rcampli is offline   Reply With Quote
Old 09-22-2018, 09:19 AM   #2
nomad297's Avatar
You have a tripped GFCI outlet somewhere.
Bruce
Old 09-22-2018, 09:23 AM   #3
Bruce
Bathroom GFCI is ok
Old 09-22-2018, 09:26 AM   #4
Mr. Dan's Avatar
A microwave oven should not be on a GFCI circuit.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 0; booked = 14
Old 09-22-2018, 09:40 AM   #5
while not fore sure the microwave is probably on its own circuit. go flip the breaker of then back on just to eliminate it. if still no power you can pull the receptacle out and look for a loose wire. a non contact voltage tester might be able to tell you if there is power running to the receptacle even before you pull it.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is online now   Reply With Quote
Old 09-22-2018, 09:44 AM   #6
Did the Micro work before with the Air "1 or 2" running while on Gen? Youroo! !
Old 09-22-2018, 10:37 AM   #7
It worked with both and it worked without the air which was the scenario this morning. I turned the Generator on and usually the clock comes up after maybe 20 seconds today nothing. All the outlets work except the microwave
Old 09-22-2018, 10:38 AM   #8
Except Microwaves Outlet
Old 09-22-2018, 10:53 AM   #9
cavie's Avatar
Please respond to post #5
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 09-22-2018, 01:24 PM   #10
After pulling the outlet I was not getting any power to the outlet. I replaced the circuit breaker with a new one and still no power to the outlet nor wires the Microwave works if plug it in to another outlet
generator, microwave
