Originally Posted by georgew48
For a year and a half now me and the dealer have been trying to fiigure out why my main tv is fuzzy on cable and the other two were fine. Finally I tore into the center cabinet and after much tracing found out the four way splitter was totally hooked up wrong. They had the cable in hooked up to the out and the main tv hooked up to the in. I don't know how any if the tvs were working. After hooking up all cables properly everything works fine. I also replaced the four way splitter with a new one just in case the old was was ruined because of the improper hookup. Quality control is non existent. Oh, and some how it worked during the PDI. Don't have a clue how that happened.
So yours was behind the wood in the center cabinet.
Was the antenna amp located there also or in the right compartment
I ask because I tried to pull the coax fromt he right compartment to the splitter and was unable to see it or get to it.
It just may be behind the center cabinet wood instead of the right cabinet were the coax comes out of the back of the cabinet.
Any pics?
Glad you found and repaired.
