Old 03-30-2012, 01:52 PM   #1
mbtelguy's Avatar
Modified Converter - Battery Wiring - OK?
With the current FR wiring on the 378ts the battery on/off light is very misleading. If you operate the battery on/off switch to disconnect the battery from the load, with no 110AC shore power, the battery light goes out. However if you connect to shore power now under this situation the battery light will come on giving the impression that the batteries are connected to the load and
are being charged.
The attached schematics show the current and proposed wiring.
My question, does anyone see a problem with this change ??
mbtelguy is offline   Reply With Quote
Old 04-02-2012, 06:10 AM   #2
CLASS "A" Senior Member
cfsoistman's Avatar
Georgetown-Battery Connect Center.pdf
Battery Control Center Information -1.pdf
Battery Control Center Information -2.pdf
You may want to refer to the above information before any rewiring. Your batteries also charge from the alternator as well as your engine battery can charge from the converter.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
battery
