Old 07-28-2016, 02:24 PM   #141
SternHappens's Avatar
As to Sewer Hose storage. I did a simple fix. Bought one of those under the bed plastic storage bins (long rectangle deep enough for the sewer hoses) and put it in through the door just behind the propane tank. I have no idea what that is in there but something covered with a black plastic cover only take up half to a third of the space. there is plenty of room above it for the storage bin to slide in. I just used a few bungees to hold it. Was an experiment at first, but after 16,000 it's still sitting in there every time we stop...so far!
2015 Georgetown 364TS, '14 Fiesta 5 spd w/Tandem Tow Dolly HDXL 8x10, & EZGO Customized Cart
'16 - 59 days; '15 - 56 days
2011 Flagstaff V-Lite 30WFKS '14 - 24, '13 - 33, '12 - 36, '11 - 29, '10 - 23
SternHappens is offline   Reply With Quote
Old 07-29-2016, 06:47 PM   #142
Originally Posted by ChrisAndGarren View Post
Best modification we ever made on our 351 - used a 5x5 plastic fencepost and some plastic gutter as a slide - attached with heavy duty zip ties underneath. We had to run it diagonally in our 351, from the propane area to the battery area (next to the entry stairs) for it to fit. Works like a charm!
Garren
Do you have any pics of your mod?
Melvinson404 is offline   Reply With Quote
Old 07-29-2016, 08:39 PM   #143
AquaMan's Avatar
The black plastic cover is where the hydraulic pump and reservoir is.
2016 Georgetown 364TS
Nights Camped
2014 - 56
2015 - 41
2016 - 81
AquaMan is online now   Reply With Quote
Old 08-03-2016, 06:13 PM   #144
Solera 2013 24S
Have a mod question, I just bought a 2011 350ts, the cabinets above the sink have 2 shelves. The top shelf is 1/2 the depth of the bottom shelf and has a very short lip on the shelf. I am looking for something to hold the top shelf stuff to stay put when driving and opening door. The width is 44 in so cabinet bars won't work. Any ideas out there? Thanks
Leismom is online now   Reply With Quote
Old 08-03-2016, 06:32 PM   #145
AquaMan's Avatar
Use a tension curtain or shower rod.
Nights Camped
2014 - 56
2015 - 41
2016 - 81
Old 08-03-2016, 06:36 PM   #146
Solera 2013 24S
Perfect. Thanks
Old 08-03-2016, 08:45 PM   #147
Ditto, shower rob much thicker but more study if holding back heavier items. I curtain rod thinner and easier to pop in and out of your way while set up, but may move some depending on load, will hold things back but may be shifted some.
Old 09-18-2016, 11:39 AM   #148
Not so much a mod as an adjustment, but relocated the flip up counter extension from behind the sink (alongside of door) to the side so the wife can actually use it now. doesn't cut into the clearance of coming and going through the door and gives her a bit of usable space next to the sink now. The extension is about 3" longer than that edge of the counter so I made it even on the door side edge and it comes in a small amount on the sink side but doesn't seem to interfere at all w/sink access. It's my understanding that not everyone has these installed in their units. Anyone else have one?
Name:	Counter Ext relocation.jpg
Old 09-18-2016, 11:44 AM   #149
No but would love one. Any pictures of how it works? Is it just hinged?
2016 Georgetown 364 TSF
2015 FunFinder 242BDS traded for above
2014 Starcraft 1221 Comet traded for above
Modmike is offline   Reply With Quote
Old 09-18-2016, 11:54 AM   #150
Attachment 120530
Wow no mine does not, I wonder why they killed it, maybe 2016's?
I would love to have that, guess I'll have to order one now!
2016 364TS
Kevin M. is offline   Reply With Quote
modifications
