Old 03-08-2016, 02:19 PM   #11
toolman_57
Posting pictures to get inverter power to the outlet next to the entrance (sink cabinet). Note that last picture is the junction box next to the inverter switch showing wires in/out.
ID:	101392   Click image for larger version
ID:	101393   Click image for larger version
ID:	101394   Click image for larger version
ID:	101395   Click image for larger version
ID:	101397   Click image for larger version
ID:	101398   Click image for larger version
ID:	101399   Click image for larger version
toolman_57 is offline   Reply With Quote
Old 03-08-2016, 03:50 PM   #12
Thanks for the information on that Toolman 57. I was surprised that there was an electrical outlet behind the original couch. I plugged in a light strip around the couch for a little extra looks too.
I have been very happy with the performance of the coach. I just ordered the 5 star power pack for it. I'm hoping that there will be fewer down shifts in the hills.
Roger 2650
2015 GT 364ts
Roger2650 is offline   Reply With Quote
Old 03-08-2016, 04:37 PM   #13
360true's Avatar
We didn't like the curtains in the living room on our 2014 378. Was able to order a dual shade directly from Irvine Shade (OEM) and rescued a piece of trim from my dealer's bin. Used it to make a valance for it.
360true is online now   Reply With Quote
Old 03-08-2016, 06:14 PM   #14
toolman_57
Roger 2650
2015 GT 364ts
After we added the power recliner, I added a power cable to the outlet shown in the picture and ran it under the coach to the junction box under the main slider. Switched out the current power to the two AC outlets in the slider. I've powered a laptop on the kitchen table, 2 recliners, tv, dish receiver, tivo, and refrigerator off the inverter. When boondocking we go about 4 hours using the inverter, run the generator for about 15 minutes and head off to bed. No problems so far.
Old 03-09-2016, 02:47 AM   #15
AquaMan's Avatar
I ran inverter power to the door side outlet yesterday. Worked perfect. May look into doing the outlet under the passenger side dash. Suppose to be above freezing for the next couple weeks here, so may de-winterize and get ready for trip to FL. Has anyone thought of adding another awning? I would love to add an awning over the slide bunk slide. My only concern at this point would be the mounting arm in front of the slide. Not sure there is frame work available that wouldn't interfere with slide. Other possibility is to add to slide itself. 12' of awning is just not enough.
2016 Georgetown 364TS
Nights Camped
2014 - 56
2015 - 41
2016 - 81
Old 03-16-2016, 08:34 PM   #16
Installed the 5 star custom tune today. The engine seemed to run stronger. The test will come after this next Tuesday (3/22/16) when we will be headed back to Wisconsin.
I think 1600 miles should tell the story on the tune.
Old 03-16-2016, 10:26 PM   #17
What's the cost on this tune?
Kevin M. is offline   Reply With Quote
Old 03-16-2016, 10:46 PM   #18
SternHappens's Avatar
Roger2650, which one did you get? there seems to be a few different ones.
SternHappens is offline   Reply With Quote
Old 03-17-2016, 07:06 AM   #19
Originally Posted by AquaMan View Post
I ran inverter power to the door side outlet yesterday. Worked perfect. May look into doing the outlet under the passenger side dash. ...
If you look at the 2016 models, they put an outlet right in the lower dashboard on the passenger side. I have an inverter that runs all of the driver side plugs, including the ones in the storage compartments over the dash. Would love to know how the feed gets there so I could put one in the dash just like the new models.
2015 335DS
ScottBrownstein is online now   Reply With Quote
Old 03-17-2016, 10:49 AM   #20
Kevin: I paid $489.00, that included shipping of $9.95. It installed inside of 20 min. Easy to do, just follow the prompes on the screen.
sternhappens: I bought the 5 star custom tunes, which was mentioned in an earlier reply on this forum.
modifications
