03-26-2016, 07:59 AM
#41
On our way to FL a couple days ago, we experienced high winds and it was quite a challenge at times keeping it in the lane. I will definitely be looking into some type of fix or improvement
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
03-26-2016, 08:13 AM
#42
I've installed rear tracbar, front steering stabilizer, and front and rear Roadmaster anti-sway bars. All this resulted in a "moderate" improvement. I do have 19.5" tires, but can't get anyone at Ford or FR to definitively say whether or not it makes a difference. All that aside, we love our 364TS so much that I've just decided to enjoy the ride as is.
2018 Berkshire 38A
03-26-2016, 09:24 AM
#43
Vince and Charlette, what front steering stabilizer did you go with? Roadmaster? We also love our 364TS and are 3 weeks away from our longest trip ever camping - 32 days cross country.
2015 Georgetown 364TS, '05 TJ flat, or '14 Fiesta 5 spd w/Tandem Tow Dolly HDXL 8x10, & EZGO Customized Cart
Days Out '17-25{Days in Shop 141}; '16-59; '15-56.
2011 Flagstaff V-Lite 30WFKS '14-24, '13-33, '12-36, '11-29, '10-23.
03-26-2016, 09:25 AM
#44
We are set up in our 364TS and have been watching TV for 2 days, all of a sudden TV pictures freezes, change channel no signal, look up and no power on the King Jack antenna (had just been working fine) checked fuses over bed, nothing blown, everything else seems to be working, lights in kitchen, etc. Any idea where the fuse for the king jack is hiding?
#45
We are definitely loving ours, even with the 5.4mpg that we got coming down to FL. That was pulling a toad and running 70.
03-26-2016, 09:32 AM
#46
You didn't by chance push the button off on the booster in the cabinet did you?
03-26-2016, 10:25 AM
#47
Where are you? If I am ever in your area I can let you try mine so you can see if the 22.5" makes enough of a difference for you to consider upgrading your wheels.
It would be great if we could have a rally and try each others rigs to see if there is any difference when suspension fixes are added. I gather most people would be uncomfortable with that though.
2016 Georgetown 364 TSF
2015 FunFinder 242BDS traded for above
2014 Starcraft 1221 Comet traded for above
03-26-2016, 01:13 PM
#48
Aquaman, no one touched anything we just had the TV on and blink out it went. I did the usual flip the power switch on and off a couple times and tapped the case to no effect. finally went to push the button in to jiggle the antenna and blink there it was. Someone on another thread said the king jack has a self resetting fuse that will blow when it gets hot. Think there is a loose connection up inside there somewhere. If it happens again, I'll explore more. Also just finished the CHF to the front end. We'll see if that makes a difference on the way home tomorrow.
03-26-2016, 09:43 PM
#49
SternHappens, The tracbar is a Blue Ox TT2401. Stearing stabilizer is a Roadmaster RBK9. Modmike, We're southeast of Dayton, OH. I'd love to take a test drive if you're within an hour or two of me.
2018 Berkshire 38A
03-27-2016, 05:56 PM
#50
Any ideas for a shade for the entry door window?
03-27-2016, 06:48 PM
#51
Melvinson404, My wife made a simple panel out of a piece of old curtain she had. We used command picture hanging velcro to attach it, so pulls off if we need it to. The command stuff seems to work great throughout the RV.
03-28-2016, 08:28 AM
#52
Excellent question - I think this is a common over site in many of the Georgetowns. I put up some only Reflectex that I had laying around but not very pretty - provides shade and privacy. I too am looking for other solutions.
Mickey Alberto
2020 F350 4X4 6.7 CCLB, SRW
2020 Heartland Elkridge 38MB
03-28-2016, 09:30 PM
#53
toolman_57
We used an expandable (by twisting) curtain rod and a dark brown curtain panel. The rod goes between the tv cabinet and the passenger window "box." I can't remember how long the panel is but it drops all the way to the bottom step. We leave it in place, just slide the curtain towards the front of the coach. When we hit the road, we tuck the bottom of the curtain next to the passenger seat. Still waiting for the dealer to finish waranty repairs, then will provide pictures.
04-03-2016, 09:33 PM
#54
Projects this weekend. Aside from having to remove the rear toilet to fix a leak coming from the crimp on connector going into the 90 degree elbow, now has a nice and tight hose clamp as well as reworked the crimped white hose on the back of the toilet, now a new piece of hose and 2 new tightened hose clamps. I finally installed a shelf over the washer/dryer. Lot of square footage there that wasn't able to maximize because of the spaces on either side and the back, if you lose something back there it is gone...
04-03-2016, 09:44 PM
#55
04-03-2016, 09:53 PM
#56
and finished!
Now to wait a few days for my sore arm to heal up and I can relax under the front end and install the Roadmaster steering stabilizer RBK9, found on Amazon for $323.55 for the reflex stabilizer and the mounting bracket. Looks like an easy install, just need some arm strength back to bust the nuts loose to install the bracket.
04-04-2016, 02:21 PM
#57
Very nice on both storage mods!
04-09-2016, 09:03 AM
#58
Mods to my 2015 364TS
04-09-2016, 09:27 AM
#59
Melvinson404, looks good. I smashed my earlobe wrenching my head in there, nice and black and blue for a few days. I consider all the bumps, bruises, scratches, sore muscles and aches & pains to be well worth it when you get to the finished result and can relax and enjoy...
04-09-2016, 10:13 AM
#60
I should have asked in my post but will here so the other one can die...where did you get you License Plate mount at? That does look good/normal.
Mickey Alberto
