Old 03-26-2016, 08:59 AM   #41
AquaMan's Avatar
On our way to FL a couple days ago, we experienced high winds and it was quite a challenge at times keeping it in the lane. I will definitely be looking into some type of fix or improvement
2016 Georgetown 364TS
Nights Camped 2017 - 49
Old 03-26-2016, 09:13 AM   #42
Vince and Charlette's Avatar
I've installed rear tracbar, front steering stabilizer, and front and rear Roadmaster anti-sway bars. All this resulted in a "moderate" improvement. I do have 19.5" tires, but can't get anyone at Ford or FR to definitively say whether or not it makes a difference. All that aside, we love our 364TS so much that I've just decided to enjoy the ride as is.
2018 Berkshire 38A
Vince and Charlette is offline   Reply With Quote
Old 03-26-2016, 10:24 AM   #43
SternHappens's Avatar
Vince and Charlette, what front steering stabilizer did you go with? Roadmaster? We also love our 364TS and are 3 weeks away from our longest trip ever camping - 32 days cross country.
2015 Georgetown 364TS, '05 TJ flat, or '14 Fiesta 5 spd w/Tandem Tow Dolly HDXL 8x10, & EZGO Customized Cart
Days Out '17-25{Days in Shop 141}; '16-59; '15-56.
2011 Flagstaff V-Lite 30WFKS '14-24, '13-33, '12-36, '11-29, '10-23.
SternHappens is offline   Reply With Quote
Old 03-26-2016, 10:25 AM   #44
We are set up in our 364TS and have been watching TV for 2 days, all of a sudden TV pictures freezes, change channel no signal, look up and no power on the King Jack antenna (had just been working fine) checked fuses over bed, nothing blown, everything else seems to be working, lights in kitchen, etc. Any idea where the fuse for the king jack is hiding?
Old 03-26-2016, 10:25 AM   #45
AquaMan's Avatar
We are definitely loving ours, even with the 5.4mpg that we got coming down to FL. That was pulling a toad and running 70.
Old 03-26-2016, 10:32 AM   #46
AquaMan's Avatar
You didn't by chance push the button off on the booster in the cabinet did you?
Old 03-26-2016, 11:25 AM   #47
Where are you? If I am ever in your area I can let you try mine so you can see if the 22.5" makes enough of a difference for you to consider upgrading your wheels.
It would be great if we could have a rally and try each others rigs to see if there is any difference when suspension fixes are added. I gather most people would be uncomfortable with that though.
2016 Georgetown 364 TSF
2015 FunFinder 242BDS traded for above
2014 Starcraft 1221 Comet traded for above
Modmike is offline   Reply With Quote
Old 03-26-2016, 02:13 PM   #48
Aquaman, no one touched anything we just had the TV on and blink out it went. I did the usual flip the power switch on and off a couple times and tapped the case to no effect. finally went to push the button in to jiggle the antenna and blink there it was. Someone on another thread said the king jack has a self resetting fuse that will blow when it gets hot. Think there is a loose connection up inside there somewhere. If it happens again, I'll explore more. Also just finished the CHF to the front end. We'll see if that makes a difference on the way home tomorrow.
Old 03-26-2016, 10:43 PM   #49
SternHappens, The tracbar is a Blue Ox TT2401. Stearing stabilizer is a Roadmaster RBK9. Modmike, We're southeast of Dayton, OH. I'd love to take a test drive if you're within an hour or two of me.
2018 Berkshire 38A
Old 03-27-2016, 06:56 PM   #50
Any ideas for a shade for the entry door window?
Melvinson404 is offline   Reply With Quote
modifications
