Old 04-09-2016, 11:53 AM   #61
Originally Posted by cmalberto View Post
I should have asked in my post but will here so the other one can die...where did you get you License Plate mount at? That does look good/normal.
It's a modified plate mount from a 2015 Chevy Equinox (go to any Chevy dealer parts Dept to get it). The newer model Chevy lineup has a similar shape to the bumper. Used a belt sander to get the angle right to fit the GT bumper. It really looks like it came from the factory that way now. Pretty pleased with the results...
Melvinson404 is offline   Reply With Quote
Old 04-09-2016, 11:31 PM   #62
SternHappens's Avatar
Here's a simple little project for the purpose of making it easier to access the Frig while driving yet keep it from popping open around corners. While the bungee works fine for the freezer, it doesn't work very well for the frig doors.
Name:	Frig door lock rough.jpg
Name:	Frig door lock finished.jpg
2015 Georgetown 364TS, '14 Fiesta 5 spd w/Tandem Tow Dolly HDXL 8x10, & EZGO Customized Cart
'16 - 51 days camping so far, 19 more min planned; '15 - 56 days
2011 Flagstaff V-Lite 30WFKS '14 - 24, '13 - 33, '12 - 36, '11 - 29, '10 - 23
SternHappens is offline   Reply With Quote
Old 04-10-2016, 12:47 PM   #63
Senior Member - Retired
Your refrigerator door restraint looks great. Assuming it is made out of wood (plywood or ?) is it painted red or did you use plastic-dip? What are the rough outside dimensions?.
John & Gloria Hunsaker FROG Member CA-0030-988
2014 Georgetown XL 334QS (class A with 4 slides)
2013 Smart Car TOAD
Blue Ox Aventa LX tow bar, base plates, diode kit
SMI Stay-IN-Play Duo auxiliary braking system
25' Off shore blue water fishing boat
CA Fisherman is offline   Reply With Quote
Old 04-10-2016, 04:53 PM   #64
RVnut's Avatar
Originally Posted by SternHappens View Post
Finally tackled the space behind the TV in the bedroom. Was fortunate that I didn't have to rework the shelf I've already installed. The only thing I had to do was cut a notch in the top left of the door for the door to open wider and not hit the shelf bracket too quick. Used a double shallow outlet box so I could relocate the power outlet and have access for the cable to feed though. You can't tell the difference when finished other than not having to empty the stuff sitting on the bed while traveling, it now has a home!
Attachment 103802
Attachment 103803
Attachment 103804
Attachment 103805
Can you tell me how the Seiki TV comes off the wall?? Thanks
364 Georgetown 2016
in Montana
RVnut is offline   Reply With Quote
Old 04-10-2016, 05:12 PM   #65
AquaMan's Avatar
Mine had about 5-6 screws through the plywood from the back side, into a piece of plywood bolted to the tv.
2016 Georgetown 364TS
Nights Camped
2014 - 56
2015 - 41
2016 - 81
Old 04-10-2016, 05:52 PM   #66
RVnut's Avatar
Thats what mine looks like to and I was trying to figure out how to get to the back side
364 Georgetown 2016
in Montana
Old 04-10-2016, 07:16 PM   #67
AquaMan's Avatar
There is a panel in the left side closet that you can remove and reach through.
Nights Camped
2014 - 56
2015 - 41
2016 - 81
Old 04-10-2016, 09:19 PM   #68
Aquaman, must have had the upscale mount, mine had 3 screws going from inside through the wall and into a peice of plywood that was screwed into the TV mounts with a couple of small metal strips. Definitely a 2 person job, one to hold the tv and one to wrench their through the hole in the closet to the front wall of the deadspace. I found a locking bracket on amazon that wasn't more than $10-15, easy to lift TV on and off and a you reach from underneath and flip a little lever and it locks the Tv onto the wall plate.
Old 04-10-2016, 09:21 PM   #69
AquaMan's Avatar
I thought of going that route, but once I had the tv off and the door made, it was easy to screw it back on the front.
Nights Camped
2014 - 56
2015 - 41
2016 - 81
Old 04-10-2016, 09:26 PM   #70
CA Fisherman, The frig hook is 1/4" plywood, the dimensions are roughly 11" x 18", each leg 3" thick with a 5" space in the middle, across the top 5" thick as well. I coated it with red felt by using Elmers spray on glue for the flat sides and brushing on wood glue along the edges. First attempt came out workable, had to re-position some of the magnets covering the frig, and if I was going to make another one, I would flair out the legs at about 5" down on the inside maybe just an inch or so on each side, this would allow for easier on and off and still be tight since the 5" x" 5" center is what holds the door tight. So would look like a modified upside down V. Don't use anything more than a quarter inch thick either. Wife thinks this is much easier to get to the frig while moving as opposed to the baby proof straps we were using on the frig doors prior.
modifications
