Old 01-11-2015, 02:34 PM   #1
Moisture on Headboard
Just a heads up for cold weather campers. We are parked at a National Wildlife Refuge near Austin, TX and have been here for over a month. The last week or so the temperatures have not been what you would call warm, staying just above 35 to 45 during the day and dropping below freezing at night. No problem keeping the coach warm using a couple of ceramic heaters and the heat strips in the a/c units but did discover a lot of moisture on the wall where the mattress is pushed up against the inside of the slide outside wall. We pulled the mattress back away from the wall about 6 inches and it dried right up. So...if it's been cold outside for awhile you may want to check for condensation next to the mattress. Cheers!
2011 Georgetown 378TS in FireMist
2013 Jeep Wrangler Toad
Kirby the Old Dog, passed but still in our hearts
Max E. Dog, the new pup
Eureka the Old Cat, still hangin' on
Lostdog is offline   Reply With Quote
Old 01-11-2015, 02:41 PM   #2
Looking Down Range
SkipnTerri's Avatar
That's good to know. We often get spring fever and head out before the temps are above freezing at night.
2014 Forester 3051S
2013 Ford Focus
SkipnTerri is offline   Reply With Quote
Old 01-12-2015, 11:25 AM   #3
chrisbailey13's Avatar
we had/have a similar problem with our bunks. when it is exceptionally cold outside, the wall next to the lower mattress gets a little damp. if I pull the mattress away from the wall it dries right up, but it concerns me that it may create a mildew issue.
2014 Georgetown XL 352QS
2013 Days Camped-10 (in a rental)
2014 Days Camped-52
2015 Days Camped-53
2016 Days Camped-32
chrisbailey13 is offline   Reply With Quote
Old 01-12-2015, 12:03 PM   #4
Ret E-9 Anchor-clanker
donanddona's Avatar
We run a dehumidifier when turning on ceramic heaters, sometimes during periods of high humidity. Bought a section of pvc to put at the head of the mattress to prevent mildew.
donanddona is offline   Reply With Quote
Old 01-12-2015, 12:06 PM   #5
Brother Les's Avatar
Need more 'air flow' in the unit. have a small fan move the air around a little.
Brother Les
Old 01-17-2015, 08:22 PM   #6
ramair's Avatar
one thing you can do is leave one of the vents open a little and as said before use a fan to help circulate and move the air.
Andrew & Donna Reyes
2012 Georgetown 378XL
2015 Ford Taurus
Our Baby Dachshund
ramair is offline   Reply With Quote
