Old 12-03-2015, 06:57 PM   #1
tpfosterjr's Avatar
Mold under clear film
We have a 2011 373 Georgetown, we wash it often to keep it clean, but within the past year, we have noticed that the clear flim that is on the front end, there seems to what looks like mold film. No matter what can't seem to get it off, it's like the mold is between the clear film and paint. Anyone else have this problem?
tpfosterjr is offline   Reply With Quote
Old 12-03-2015, 07:30 PM   #2
Casper
williamsgw's Avatar
We have a 2015 328 TS and so far we don't have any. But FR has painted the front end twice due to paint flaws.
williamsgw is offline   Reply With Quote
Old 12-03-2015, 08:18 PM   #3
VinceU's Avatar
Yes I've seen it in a number of Diesel pushers. Normally starts near 10 year age. It's harmless mold but under the shield cannot be removed. Only cure is to have a shop remove the shield very carefully, paint stays intact.
Old 12-03-2015, 08:52 PM   #4
tpfosterjr's Avatar
That's what I was thinking, getting a body shop to try and remove the clear film. Thanks
Old 12-04-2015, 06:24 AM   #5
VinceU's Avatar
One vendor I've seen it, Dazzling Detail, Orlando Fl. 1-877-232-0100 or 407-948-9284. Dazzlingdetail@live.com great job.
Old 12-04-2015, 07:47 AM   #6
tpfosterjr's Avatar
Thanks, will look into it
Old 12-05-2015, 06:17 AM   #7
Just removed the diamond shield from my 378, the mold is between the clear and the paint and no other way to remove it. If you take it to a vendor to remove, it will not be cheap. In most cases when you remove the film, some (or most) of the glue residue will remain and be a PITA to get off. Worst case scenario some paint will come off with the film. I was fortunate that most of my glue came off with the film, the areas that did not I used 3M adhesive remover to get it off (tried several methods and 3m worked the best) Good luck, and hope you dont have any issues.
Carmen is offline   Reply With Quote
Old 12-05-2015, 10:54 AM   #8
Call Diamond Shield. Their rep removed my original clear covering and replaced it. It might be under warranty.
nicholsonv is offline   Reply With Quote
Old 12-05-2015, 12:22 PM   #9
Unfortunately I wasn't the original owner and the lifetime warranty isn't transferable
Old 12-05-2015, 12:49 PM   #10
VinceU's Avatar
Why did you have to remove it so soon. How did you do it?
mold
