Old 01-09-2011, 06:16 PM   #31
rebmeM
kenn's Avatar
Originally Posted by herk7769 View Post
That is why I did the 100% conversion to LED lights. Now my battery lasts almost 10 times longer than previously.
Did you replace fixtures as well or did you just replace bulbs?
2014 F-350
2011 Stealth 2612
kenn is offline   Reply With Quote
Old 01-09-2011, 07:05 PM   #32
Herk7769's Avatar
Just the bulbs. I will post a photo of them installed if anyone is interested. I will be in the camper getting it ready this week.
HAM CALLSIGN - KC3FFW
Old 01-10-2011, 11:52 AM   #33
RV Custom Products
Although very poor quality schematics, try this site for a copy of a trouble shooting guide for the subject BCC.
http://www.discoveryowners.com/BCC.pdf
Gary
mbtelguy is offline   Reply With Quote
Old 01-10-2011, 12:29 PM   #34
Pete
gartonhl's Avatar
Just got this from RV Custom Products on Friday. Was curious also as to their setup. Hopefully this will lend you assistance.
Pete and Patty
2010 Georgetown 378TS; 2012 4dr Jeep Rubicon
1 Yellow Lab (hers);1 Little Bitty dog (mine)
gartonhl is offline   Reply With Quote
Old 01-10-2011, 01:46 PM   #35
BCC Drawing
Hi Pete
I to have a 378, and found by accident a schematic, the same as the one from RV Custom Products pasted to the underside of the cover we remove to service the batteries. The only difference is the one on the cover provides more information on the fuses.
In addition I obtained from Geogetown the following schematic of the external wiring to the BCC.
File Type: pdf Georgetown Battery Connect Center 113174 1 OF 1.pdf (309.9 KB, 52 views)
Old 01-10-2011, 02:03 PM   #36
Pete
gartonhl's Avatar
Thanks mbtelguy,
I appreciate it.
Info exchange on this site is very beneficial.
Pete and Patty
Old 01-10-2011, 04:56 PM   #37
jsutherl's Avatar
Wow that's great. Nice work!
2008 Georgetown SE 350DS BunkHouse
jsutherl is offline   Reply With Quote
Old 07-17-2012, 09:24 PM   #38
ME
sparks1032's Avatar
I realize this thread is over 18 months old but I am curious on how things held up.
1-I do not like the set up of the batteries under the stairs and being exposed to the elements when driving and or camped. So how have the batteries held up?
1a.- I thought about adding another storage compartment in front of the entry door as I can find the door to add easy but not the plastic inside to match and putting the batteries inside that compartment.
2.- Has your stock converter been able to charge the four battery set up?
2a- If not what have you gone with?
3. Did you add any monitoring equipment such as gauges?
4. There was some discussion about moving the batteries and confirming the length of battery cables did this occur? and if it did was it necessary?
5. PM me if this is to old to bring to life!
2008 Georgetown 350TS
sparks1032 is offline   Reply With Quote
Old 07-18-2012, 04:48 PM   #39
jsutherl's Avatar
Sparks,
So far so good. I've got the four batteries in there still that you see in the pictures. They have not been moved. They get dirty being under the step like that but that doesn't hurt them any. I'm happy with them where they are.
I used the stock converter for about six months and it worked fine to charge these batteries. The way 12v chargers work pretty much any converter will charge any size bank of batteries. It'll just take longer to charge if you have a small converter. The converter in mine was a 60amp which is plenty big enough.
Later I added a Xantrax LinkPro battery monitor (I made a post about this with pictures). It does a great job of telling me how the batteries are doing.
After that I installed a whole house inverter. The inverter is now the charger for the batteries. The old converter is still installed but just unplugged from 110v. The Inverter only charges at 40 amps but that's still plenty to charge up my batteries.
Old 07-18-2012, 04:50 PM   #40
jsutherl's Avatar
Here is the post about the battery monitor.
Xantrex LinkPro Battery Monitor
georgetown, battery
