Old 09-30-2012, 05:13 PM   #1
Motorized Front Shade Stopped going down
We just picked up our new Georgetown 350 last week (2013 model). We love it !! However it has had a few problems to start out and the most frustrating is the motorized shade stopped working and will only go up. Has anyone else had this problem and is there an easy fix?
MGOBlue is offline   Reply With Quote
Old 09-30-2012, 05:44 PM   #2
410 QS 425 2011 Birkshire
re-programming automated sunshade instructions
malewis49 is offline   Reply With Quote
Old 09-30-2012, 09:10 PM   #3
Navion IQ 24V
Mine quit working while we were doing the initial shakedown on the lot. They replaced it on the spot and has been trouble free since.
Sold 2012 Georgetown 350F Gasser
Navion IQ 24V
Wildhog56 is offline   Reply With Quote
Old 09-30-2012, 09:47 PM   #4
Iggy's Avatar
You do know that if the engine is running it only goes down about a foot.
Only when you have the engine off it will go down all the way.
Just wanted to check if you knew this.
Check the document above on how to re-program it.
Old 09-30-2012, 09:53 PM   #5
VinceU's Avatar
Its not simple, recommend your dealer does it when you get your repair list together. Biggest problem is access
Old 10-01-2012, 08:06 AM   #6
Our 378 is in the shop right now for this same problem. The darn thing simply will not hold it settings. I have reprogrammed it at least 25 times. I REPROGRAMMED IT EXACTLY LIKE THE MANUAL SAID TO. The reprogramming "may" last a day then it has a mind of it's own again. Called the factory (MCD Innovations) and the tech said it was low battry voltage. Checked the voltage at the switch numerious times and it showed 12.3 to 12.9 volts everytime. Not low voltage!!!!!! MCD sent a new motor assembly at cost and I went to take the shade down, couldn't get it down and decided not to let my anger with this piece of c*** cause me to rip it down and replace with towel or something that works. Took it to the dealer to have the new motor installed. The motor was about $60 and probably an hour of labor at the dealership. WE SHALL SEE.......
Lostdog
2011 Georgetown 378TS in FireMist
2013 Jeep Wrangler Toad
Kirby the Old Dog, passed but still in our hearts
Max E. Dog, the new pup
Eureka the Old Cat, still hangin' on
Lostdog is offline   Reply With Quote
Old 10-01-2012, 08:13 PM   #7
I called United Shade and the tech support guy walked me through the reprogramming. It works fine for the moment. We'll see how long it lasts.
Old 10-02-2012, 05:57 AM   #8
Got it back yesterday and it seems to be working with the new motor assembly. Only time will tell.
Lostdog
Old 10-06-2012, 04:47 PM   #9
If it fails again, try measuring the voltage while the shade is moving. A bad connection from the battery may show full voltage with no load but should show a lower voltage when the motor is drawing current.
Phil
pmsherman is offline   Reply With Quote
Old 10-08-2012, 10:37 AM   #10
copsuno's Avatar
To All, another point to watch for. I had same problem and reset and worked fine until the Passenger side screws that hold the shade up, vibrated loose and shade was moving off center and chewed up passenger side edge of shade. I am out of warranty so they fixed screws, no charge, but stuck with shade. Not a major problem as the damaged area is in the track and not that noticeable. Just FYI.
Logic will carry you from point A to point B. Imagination will carry you everywhere. "Albert Einstein". 2011 Georgetown 360, Bride of 45yrs, and 2014 Chev Equinox toad, what more could you ask for.
copsuno is offline   Reply With Quote
