Old 05-02-2011, 11:49 AM   #11
Pete
gartonhl's Avatar
Mileage is ugly for sure when doing Red Mountain from Ouray to Silverton.
Be SAFE!
When I did it, driving "UP' the mountain and navigating the turns wasn't bad. It was the coming "DOWN" that bothered me. LOWER gear for sure! But, I still used the brakes and they really heated up and start smelling. I pulled off two times to let them cool down; and then travelled on. We were towing a 2008 Jeep Liberty.
I assume you don't have many miles on your brake pads, or you haven't done many mountain decensions to use/ride your brakes. If so, you may want to check the brake pads.
Happy and Safe travelling to you!
Pete and Patty
2010 Georgetown 378TS; 2012 4dr Jeep Rubicon
1 Yellow Lab (hers);1 Little Bitty dog (mine)
gartonhl is offline   Reply With Quote
Old 05-02-2011, 12:05 PM   #12
I have an 08 378XL towing a Jeep Cherokee I get 7.5 to 8 mpg, of course that's all down hill with the wind in my back and my wife pushing for good measure. All in all if you get 7 to 8 you are doing the same as everyone else.
Remeber these are not our evey day driver's.
JDickson is offline   Reply With Quote
Old 06-27-2011, 12:34 AM   #13
jsutherl's Avatar
Filled up for the second time today. 7.16mpg this time. Better then that 3.5 of last time. No idea what happened that first time.
Maybe the locking gas cap was the key?
350DS has a 75gal tank. With the gauge indicating 1/2 tank I put in 46.738 gallons. I guess that the gauge isn't right on eh?
2008 Georgetown SE 350DS BunkHouse
jsutherl is offline   Reply With Quote
Old 06-27-2011, 06:18 AM   #14
CLASS "A" Senior Member
cfsoistman's Avatar
The Locking Gas Cap was one of the first things I bought once we got the coach home. I'd didn't want to become the filling station for anyone out there looking for free gas.
Gas gauge is pretty close but I don't believe any are exact. Ever notice how long it takes to come off "FULL" but then how quickly it drops after it reads "1/2" ?
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is online now   Reply With Quote
Old 06-27-2011, 06:48 AM   #15
Herk7769's Avatar
1) Fuel gauges are electronic sending units that rely on mechanical systems to provide the information they send.
2) Fuel tanks are not symmetrical but are shaped to fit in the assigned space.
3) It is not possible for a mechanical arm with a float on the end to travel from the top of a weirdly shaped tank to the bottom and register the same amount of fuel through it's entire range of motion.
4) The attached photo is a custom shaped F-350 gas tank. Picture an arm inside going up and down as you use fuel. Since there needs to be room for the arm to reach the bottom, the float will stop its upward movement well before the tank is full and will be submerged until the fuel drops low enough to start indicating. (Gauge reads "full" for a LONG time)
5) Depending on the shape of YOUR tank, it might take several gallons to even show you used any gas. Then drop quickly, hang out there a while and run on "empty" forever.
6) Electronic DIC (driver information center) computer systems do not care about what is in your tank. They monitor your ENGINE and display fuel USED as you drive. If you have a 36 gallon tank you can watch every drop leave regardless of its shape. The DIC in my GMC Sierra is right dead on and at places where I have to pre-pay for diesel I look at the DIC; multiply by the price per gallon and have never missed my pre-pay.
Name:	F-350 Fuel tank.jpg
HAM CALLSIGN - KC3FFW
Old 06-27-2011, 07:52 AM   #16
Our first trip in the 2011 360 gave us 7.5 mpg. That is about normal.
polkatronron is offline   Reply With Quote
Old 06-27-2011, 02:34 PM   #17
jsutherl's Avatar
Originally Posted by herk7769 View Post
1)Electronic DIC (driver information center) computer systems do not care about what is in your tank. They monitor your ENGINE and display fuel USED as you drive.
I wish the ford gave this kind of information. Aside from the gauges I get odometer, one trip meter and engine hours. That's it.
Old 06-27-2011, 09:03 PM   #18
Dodge Guy's Avatar
How often was the generator running on the first trip? 7-8 mpg is about right for a Ford V-10 hauling a load.
02 Ford Excursion V-10 4.30 gears 5 Star Tuner Y-pipe mod Hellwig sway bar Rear Airbags
Prodigy and Dual Cam
07 Cherokee 32B
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 06-28-2011, 02:35 PM   #19
jhughes3281's Avatar
A good mileage tool that I use for our cars is Fuelly | Share and Compare Your MPG
jhughes3281 is offline   Reply With Quote
Old 06-29-2011, 09:16 AM   #20
ronhanson's Avatar
Most of you are getting better than me. I get around 6.5mpg towing a car (25,500#s), and a little over 7mpg if I dont.
Ron Hanson
2009 Georgetown 350TS (bunks)
400W solar, 440AH 6V GC2
2009 Ford Edge AWD Ltd towed
2011 Honda Fit Sport towed
ronhanson is offline   Reply With Quote
