Old 05-12-2013, 11:03 PM   #1
My 2013 352qs doesn't feel stable on the road.
Hi guys, I have a 2013 352qs and it doesn't feel stable when I'm driving down the road. I'm thinking about adding sway bars. Do you guys recommend them and if so what brand? Is there a big difference in the drive? Thanks in advance for all your help.
Htab is offline   Reply With Quote
Old 05-13-2013, 05:50 AM   #2
Htab, I have a 2013 350 and felt the same way. Here's what I have done since I got mine:
1. Free suspension mod (Changing holes on swaybars from front holes to back) - Small improvement
2. Steer-safe on from axle (Big improvement in handling)
3. Blue Ox Tiger trak rear track bar (big improvement - no tail wag)
4. Rear Air Lift helper air bags (Absolute must for towing my boat)
I installed #2 & #3 above myself (very easy). And I had the airbags installed at $200. So the total I've spent on all 4 mods was about $1,400.
I'm not goingt to be one of these guys that says they drive with one finger on the wheel and never feel and crosswind or a passing truck, but I do feel much more stable and in control.
MGOBlue is offline   Reply With Quote
Old 05-13-2013, 09:17 AM   #3
Thanks for the quick response MGOBlue. I'm going to look into hose upgrades today.
Old 05-13-2013, 09:44 AM   #4
Is this a XL Georgetown? Youroo!!
Old 05-13-2013, 09:47 AM   #5
Yes it is an xl
Old 05-13-2013, 10:41 AM   #6
jojo bamboo's Avatar
I have a 2007 373 and did the same thing, kinda
$372.36 Roadmaster reflex steering stabilizer kit#RBK9
$503.97 Blue Ox Tiger Trac TT2401
It seems to be a much tighter steering wheel. non of that right & left correction.
I think the next thing I'm gonna do is install heavy duty shocks
like Koni or Bilstein
These RV'S are like boats,
ya never stop spending money on them!
jojo bamboo is offline   Reply With Quote
Old 05-13-2013, 11:19 AM   #7
CLASS "A" Senior Member
cfsoistman's Avatar
I have a 2007 as well and you'll find there are already Bilstein shocks on the RV when new. So far I've done the free mod and added air springs to front and rear.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 05-13-2013, 06:36 PM   #8
Just a thought, folks. I had the same feelings when we first got out 2011 378. The motorhome would wander on the road, felt bouncy and was a handful to drive. Had the suspension checked at the dealership where I bought it and they found nothing wrong! Mistake made...why did I take it to the dealer when it's a chassis problem????? The dealer is not a truck chassis expert. Took it to a FORD truck dealer and the problem was promply found. 65 PSI in the front left tire, 95 PSI in the right front tire and "around" 80 PSI in all four rear tires. Aired all tires to 90 PSI by the FORD folks and WOW! Drove it across the Dames Point bridge in 25 - 35 MPH quartering wind and a solid, controlled ride as good as a breadbox going thru the air at 55 MPH can expected to be. Then did the "cheap suspension fix" on the front axle. I'm well pleased with the handling now. But the biggest improvment was the tire pressures!!!!! Probably came from the factory with incorrect pressures and was never checked by the dealer. Guess what I do everytime we get underway......CHECK THE TIRE PRESSURES! And now carry my own 150 PSI compressor.
Lostdog
2011 Georgetown 378TS in FireMist
2013 Jeep Wrangler Toad
Kirby the Old Dog, passed but still in our hearts
Max E. Dog, the new pup
Eureka the Old Cat, still hangin' on
Lostdog is offline   Reply With Quote
Old 05-14-2013, 07:02 AM   #9
I have a 2014 335 Georgetown and I agree its not the best setup out of the box. I plan on doing a rear sway and something in the front this fall.
fullenw is offline   Reply With Quote
Old 05-14-2013, 09:11 AM   #10
I was talking to a local Rv shop and they said to go with a steering stabilizer and the rear sway bar
