Old 08-20-2018, 04:40 PM   #1
Airboss
Airboss's Avatar
My take on CHF or supension in general
My take on CHF
Seems every time I searched the forum for anything over half the posts that came up were about CHF which, to me, always stood for congestive heart failure. I wondered why so many motorhome owners had heart disease.
Well finally someone actually posted Cheap Handling Fix.
After my first 6 hour drive in my stock Georgetown I now understand why so many posts on the subject.
Now my head is spinning from going back over all of the CHF posts.
My impressions after reading are that a handling fix is somewhere between Gods greatest gift to mankind and totally useless.
The CHF in particular is wonderful or useless.
It also seems that unless you spend megabucks you motorhome is a deathtrap or spending megabucks is totally useless.
As always, I am sure, the truth is somewhere in between probably lies in the eyes (experience) of the beholder.
After driving my motorhome for a while now I know I am going to do something I just don’t know what.
Lots of subjective opinions by those who have done the various fixes but I am wondering is there any concrete or objective evidence for one fix over another or a combination of several. They all make mechanical sense.
Is there any data that shows stock motorhomes are more unsafe or accident prone than those with fixes.
Any reproducible measurements relative to sway, bounce, or tail wag?
Why did Ford put 2 holes in the torsion bars if all motor homes come stock with the end rods in the distal hole?
Any insurers give discounts for having done a fix.
I did find some videos on you tube with before and after videos of “their” fix that does seem to show less motion of the type the fix was supposed to address.
At this point my general plan is the CHF front and rear and a steering stabilizer possibly followed by a rear track bar.
Any thoughts on the above questions or my tentative plan?
2008 Georgetown 373 XL
Airboss is offline   Reply With Quote
Old 08-20-2018, 07:33 PM   #2
Iggy's Avatar
You have the knowledge and tools Grasshopper to accomplish the CHF.
Go forth and conquer your fears and overcome the task at hand.
https://youtu.be/j1wjvP-raOI
Watch the video Grasshopper and have confidence
2012 Georgetown XL - 378TS 63K + miles
Old 08-20-2018, 07:44 PM   #3
SeaDog's Avatar
When I had my class A I found that most of the rock and roll was driver induced. I installed heavier sway bars and bushings and started using my arm rests in the down position with my arms resting on them which really did reduce the rock and roll which without my arms resting them was my body reacting to the natural roll of the coach. Just something to think about these coaches are just like driving a big truck.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 08-21-2018, 08:11 AM   #4
My real world experience was performing the CHF on the rear increased handling and ease of driving measurably. Also added the Saf-t-steer and this eliminated the constant correcting that was needed before hand. Note my 2005 Excursion truck had a similar device stock from Ford, so I wonder why they elect not to install on the F53?
Finally, even more improvement from a front end alignment. The MoHo is now easy to drive, much easier than bone stock.
vjstangelo is online now   Reply With Quote
Old 08-21-2018, 08:27 AM   #5
Before I did the CHF I called Ford. They told me the additional sets of holes are so the suspension can be adjusted and making the adjustments were completely safe.
I am not saying the CHF is perfect but for the time and money spent it is the best thing you can do to improve the ride.
Thanks,
rkulbok
(Ron & Karin)
2015 Georgetown 328TS
Full time since October 2015
rkulbok is offline   Reply With Quote
Old 08-21-2018, 08:58 AM   #6
AquaMan's Avatar
While most do the CHF with the existing connecting arms, the geometry is off and parts will wear. A longer connecting arm should be used. Without the longer arms, the wheel travel is shortened.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 38
Old 08-21-2018, 12:36 PM   #7
wvphil's Avatar
Agree on longer links. i used BDS PN 123004 and they have worked great with no problems for over three years. The longer links will keep the sway bar level and avoid problems with sway bar hitting axle when using leveling jacks on motorhome as some have reported when using the original links. I will try and post a picture of BDS links installed. I did have to add a couple of flat washers to have them line up properly as advised by another member from this forum whom had previously completed this modification using these links.
2013 Georgetown 378 XL
wvphil is offline   Reply With Quote
Old 08-21-2018, 02:30 PM   #8
I too drive a Georgetown (31L5).
My first outing was white nuckles all the way. Handling was so bad I could barely take my eyes off straight-ahead long enough to look at my mirrors.
Long story short, I opted for a CHF.
Specs on the GT 31L5 is for 92 psi in all tires.
I gradually increased tire pressure on consecutive outings until now I carry 98 psi. Tires are rated for 110 psi.
NO MORE handling issues. Drives like a dream. No more squirily front end. Barely notice when a semi passes.
Now THAT is a CHEAP handling fix.
McCormickJim
2017 GT 31L5
McCormickJim is offline   Reply With Quote
Old 08-21-2018, 05:24 PM   #9
georgetown handling
I was ready to dump our 2018 31L5 after a couple of trips, it was impossible to drive especially near the windmills on California Route 10 with any side wind and the Virgin River out of St George a nightmare. The front bar was replaced by 1 7/8" and a supplemental rear bar of the same size installed. Tire pressure up to 90 all around and it is a different ride. 80 MPH semi's still give a little side push but nothing like before and when you turn the wheel the unit responds. I am sure all of the aftermarket corrections have value, this is what worked for me, about $1300 in parts on line, half that again for installation, not inexpensive but neither was selling the coach.
lngfela is offline   Reply With Quote
Old 08-21-2018, 06:15 PM   #10
Iggy's Avatar
After starting to drive my motorhome back in 2012 I planned on doing the CHP front and rear as well as install SteerSafe on my front wheels.
After installing these items my sway on turns were reduced and with front end alignment and proper tire pressure I ran straight as and arrow down the road with no effort at all.
I still got some tail wag when a semi was passing me and I fixed that by installing the Blue Ox TigerTrak Rear-Axle Stabilizer
It is a device that attached to the main bolts of your differential and the attaches to the frame.
It stabilized both as one and has reduced my sway on turn more and reduced my tail wag when a truck passes me. It may look like nothing but the metal they use is highly dense and heavy.
I have been using most of this since the end of 2012 and still very happy.
This is just another option to help us.
Here is a link to Etrailer where they have a video about the Blue Ox TigerTrak Rear-Axle Stabilizer
https://www.etrailer.com/p-TT2402.ht...d&hhmodel=F-53
ID:	183989   Click image for larger version
ID:	183990   Click image for larger version
