Old 04-11-2015, 12:57 PM   #21
jsutherl's Avatar
I bought small construction compressor at Home Depot that runs at 150psi.
The number one improvement you can make to any of these compressors is to buy a larger diameter rubber (not plastic) hose. Takes forever to air up one of these big tires through that tiny thin hose they give you. And if it's cold out that coiled plastic hose is worthless because it gets so stiff you can't bend it.
Harbor freight has them cheap and they carry fairly short ones.
2008 Georgetown SE 350DS BunkHouse
jsutherl is offline   Reply With Quote
Old 04-11-2015, 07:35 PM   #22
i got a small unit from harbor freight, little over 50 with coupon an it as on sale. it is 12v 150psi and needs 30a when running. it comes with a 12 ft cord and a 20 ft hose. The hose gets hot when running. I used it to pump up my truck and camper tires when my pancake unit could not do more than 50 psi..It was very cold. I have used on our new unit yet, 92 psi needed.
It is cheap and should fill my needs. I do not have space for a larger unit.
[IMG]http://www.forestriverforums.com/forums/data:image/gif,GIF89a%12%00%12%00%B3%00%00%FF%FF%FF%F7%F7%EF% CC%CC%CC%BD%BE%BD%99%99%99ZYZRUR%00%00%00%FE%01%02 %00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%0 0%00%00%00%00!%F9%04%04%14%00%FF%00%2C%00%00%00%00 %12%00%12%00%00%04X0%C8I%2B%1D8%EB%3D%E4%00%60(%8A %85%17%0AG*%8C%40%19%7C%00J%08%C4%B1%92%26z%C76%FE %02%07%C2%89v%F0%7Dz%C3b%C8u%14%82V5%23o%A7%13%19L %BCY-%25%7D%A6l%DF%D0%F5%C7%02%85%5B%D82%90%CBT%87%D8i7 %88Y%A8%DB%EFx%8B%DE%12%01%00%3B[/IMG]
happywhencamping is offline   Reply With Quote
Old 04-12-2015, 04:44 PM   #23
CheckSix's Avatar
I have a Fini Airboss. Works great!
2012 Georgetown 327DS--->2015 Georgetown XL 369DS
CheckSix is offline   Reply With Quote
Old 04-14-2015, 02:19 AM   #24
Cornelius's Avatar
x3
I have the same model from a few years ago, except it was sold as a Sears Craftsman version. I works very well for the Georgetown's 22.5 inch tires. Be certain to purchase an extra length of air hose and a locking chuck so you are several feet away in case a tire ever ruptures during inflation. The large high pressure tires used on motorhomes can be dangerous if they fail.
2010 Georgetown 373
2013 Jeep Wrangler
Cornelius is offline   Reply With Quote
