01-19-2017, 01:00 PM
Need help...ASAP
Reaching out to those who know...
Left this AM on our maiden voyage to FLA via NOLA...
In a rest stop right now. Our only cigar light does not work, so our Garnin is now dead. I found the fuse box under the hood and per the manual #22 is the fuse for the lighter...it is good, not blown.
Any suggestions where/what to look for would be helpful.
Thank you
The Otters
Sent from my SM-G900V using Forest River Forums mobile app
01-19-2017, 01:02 PM
Did you confirm the fuse was OK by just looking at it, or did you switch it with another fuse to check?
01-19-2017, 01:03 PM
Thank you
The Otters
In a lot of the GPS units, there is a in-line fuse either in the cord or in the 12V adapter plug. Have you checked to see if that fuse is blown?
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
01-19-2017, 01:04 PM
I removed it and tested it with a continuity tester as well as visually all looked good and continuity was good
01-19-2017, 01:09 PM
I have not checked the power cord to the GPS.
We have tested the cigar lighter where you insert the end of the power cord.
There is no power to the receptacle. .
01-19-2017, 01:12 PM
Do you have any other 12V device? If so, plug it in the 12V receptacle. Did it power up? If yes, Let's test the Garmin.
Do you have the USB cable that tethers the Garmin to your computer or charger?
Can you plug it in to a laptop? If so, does this power up the Garmin?
If no, you could well have a dead GPS
01-19-2017, 01:27 PM
Insert witty title here
Grab a paper map.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
01-19-2017, 01:30 PM
There is an in-line fuse under the dash right by the receptacle. 7 amp. If it is like my 335DS.
2015 335DS
01-19-2017, 01:32 PM
Does your Garmin have it's own fuse in the plug?
01-19-2017, 01:37 PM
Update !
I was looking behind the radio console and saw a 7.5 amp blade fuse. I had to remove the 6 screws from the face plate and pull it forward, radio and all. The fuse was blown !
Put a new one in and now we're on the road again.
Thank you to all !
We do appreciate your help.
The Otters
01-19-2017, 01:47 PM
That was indeed the problem Scott.
Thank you
01-19-2017, 02:07 PM
On my rig you can reach the fuse just by looking under the dash by the receptacle. Glad you found it.
2015 335DS
01-19-2017, 02:35 PM
Just stay on I-10. Cant miss it.
hate it when they hide fuses, it doesn't need to be that hard to locate a fuse.
Joe & Beverly
2014 Ram 2500 CTD, CC, SB
2014 8289WS lifted
01-19-2017, 03:06 PM
I have blown that fuse more than any other in the RV. It is a good idea to keep some extra's around for the next time. They REALLY do not like small inverters plugged in to the cigarette lighter.
2014 Georgetown XL 352QS
2013-2019 Days Camped-502
01-20-2017, 07:31 AM
chrisbailey do you have an alterative? My new 369 has one 12V (cigarette lighter) connection. I ask FR why the 110 by passenger seat was not connected to the 2000 watt inverter. They said that the inverter was just for refrigerator. I am no electrician but I know that a 2000 watt inverter will run a lot more that one refrigerator.
I have bought a slitter with 5 outlets. We run the GPS, notebook, dash cam, and 2 cell phones off of it.
What is everyone else doing????????????
Jim & Pat
2016 Georgetown XL - 369DS
Tow Chevy Equinox
Blue ox and Brake buddy
01-20-2017, 08:29 AM
Originally Posted by JBP
chrisbailey do you have an alterative? What is everyone else doing????????????
Jim,
I do...err well Silver does
Last year we installed this mod in our coach. It was dead simple (assuming you are comfortable snipping & splicing wires )
I now have ALL my 12V plugs (GPS, TPMS, Dash Cam) neatly tucked under the dash with minimal wire clutter.
I also like the Plexiglas cover Silver designed - awesome for suction cup and tacky-back mounts.
Here is a link to the 4-way 12V adapter:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
And, in one of the 12V receptacles, we installed this:
https://www.amazon.com/RAVPower-Alum...2V+USB+Adapter
Oh, the Plexiglas cover for the access plate is another $15 or so dollars, so the total cost of this mod is under $30.
Bonus: your dash 12V receptacle is now available for other uses
01-20-2017, 08:34 AM
Thank you
The Otters
I can feal your Pain! My buddy who is a Farmer lost his Stereo while he was Combining Corn,Damn near shut down the whole Operation! Youroo!!
01-20-2017, 09:19 AM
chrisbailey
Don't blame FR for the fact that only the reefer is on the inverter, blame the National Electrical Code since it requires a separate circuit for all major appliances, which includes the refrigerator. The problem is that if they branched the inverter output completely, it would have to be after the transfer switch, effectively hooking those outlets to the same breaker as the reefer. If they did it in front of the transfer switch (using the second outlet on the inverter), it would be OK with the electrical code, but the outlets would go dead when you switched to generator or shore power and there would be no way of re-energizing them.
On my RV I installed another inverter and transfer switch in the rear power bay and cut into the non-GFI outlet circuit. That way all of the outlets on the driver's side of my coach (including those in the overhead) always work.
2015 335DS
01-20-2017, 10:12 AM
you don't have google maps on your phone??
