Old 05-30-2016, 10:07 AM   #1
AquaMan's Avatar
Need help - jacks won't retract
Friend is stuck in Indy with 364TS and jacks won't retract. All lights are flashing. Any suggestions? I'm trying to help from afar but tough to do.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 05-30-2016, 10:59 AM   #2
bubbles's Avatar
Sounds like an alarm mode. Pushing all 4 jack buttons at once may clear the error. Switching ignition off and back to on is another reset.
Old 05-30-2016, 10:59 AM   #3
Krazymace's Avatar
Check the breaker. Mine is located near the batteries and hydraulic pump. Look for a little red lever. Push it back in.
Krazymace is offline   Reply With Quote
Old 05-30-2016, 11:06 AM   #4
bubbles's Avatar
With ignition on and releasing the parking brake should create an emergency retract and all lights should flash then. System off and on will reset the lights. A leak in the system can cause all light to flash if the jacks are retracted and the pressure falls below 1500 psi. Not sure if this will occur if jacks are down. Main switch blade CB may be tripped, although not sure if lights will flash if popped.
Old 05-30-2016, 01:16 PM   #5
AquaMan's Avatar
I kind of took him through all those steps but still no retract. He has service tech coming out tomorrow.
Old 05-30-2016, 04:56 PM   #6
Kinda similar to what i went through recently. My tech reset the system. The steps to do this should be attached in that thread not far down.
Im still waiting to hear back from lippert on the leaking housing. RVs might be assembled in the good old USA but the lippert parts are all chinese imports.
fullenw is offline   Reply With Quote
Old 05-31-2016, 06:55 AM   #7
AquaMan's Avatar
Going back over this morning to try a couple other things and see if we can't get it retracted. Will update
Old 05-31-2016, 11:33 AM   #8
AquaMan's Avatar
4 button reset did the trick! Thanks all
jacks
